Ford F-5 vin # help
Old 04-12-2012, 12:01 PM
Waldos's Avatar
Waldos
Waldos is offline
Ford F-5 vin # help
Hello, Just found my vin and need your knowledge. Star 8 Star 8 RT4I922 Star. Any information would be greatly appreciated. Thanks for your help!
Old 04-12-2012, 12:13 PM
51PanelMan's Avatar
51PanelMan
51PanelMan is offline
Where did you find this stamped?
Usually the trucks had two data serial tags with also a stamping on the frame rail. One tag was mounted in the upper right corner (pass side) of the cowl (inside the engine bay), another tag affixed to the inside of the glove box and a stamp of the same number on the right frame rail before the front axle.
There was another stamp on the cowl around the center top of the truck's manufactured date, color, year, etc.
Old 04-12-2012, 12:41 PM
Waldos's Avatar
Waldos
Waldos is offline
ford f-5
Drivers side main frame rail at front cross member top side. I don't know the year or anything except it has a flathead V-8. What all does the vin # tell you? Thanks
Old 04-12-2012, 09:54 PM
havi's Avatar
havi
havi is offline
I'll have the Roast Duck
Looks like a '48 F4 or F5. 8R=v8 239 cid, T=F4 or F5, 41922=serial number. No I's were used by Ford.
Old 04-12-2012, 10:29 PM
Waldos's Avatar
Waldos
Waldos is offline
Ford F-5 vin
Gentlemen, Thanks for the information, so, is the serial number the order they came off the assembly line? Thanks again!
Old 04-15-2012, 10:11 AM
harleymsn's Avatar
harleymsn
harleymsn is offline
Well, yes and no.... Ford had so many plants producing them at the time that my understanding is that they issued numbers to the various plants in groups.
You can find a lot more information about the truck from the stampings on the firewall. Most were stamped above the seam in the center, but not all. Mine was stamped above all the way to the driver's side, below the seam. Seems the Norfolk, Va plant was 'different'. For example, mine show that the truck was built on Sept. 9, 1950 and was the 729th off the line that day.
Originally Posted by harleymsn
I've had this truck for about 18 months and have been actively working on it for about 12 months. Sometime back I post the Serial# info here but never got the firewall info. I'll bet I spent 8-10 hours combined scraping, sanding and wetting the firewall trying to find the stampings somewhere in the center where everybody told me it had to be. Finally, I just gave up. Over the past week as we were preparing to paint the engine we sanded down and shot the firewall in a gloss black. that's when my wife says, "hey Joe, what are these letters and numbers over here stamped in the driver's side corner."
Well there it was, finally! Then as I was cleaning up the engine, I finally scraped and sanded the top of the block to find the engines birthday that I could not find before.
So here is the info
Engine date of manuf. H30M
H=July
30= 30th day
M= 1950
The firewall codes MNR9J729
M = Meadow Green (Wish I had found that before the paint job, but still happy with MY color)
NR = Norfolk, Va.
9 - 9th day
J = September
729 = build number
Old 04-17-2012, 10:47 AM
Waldos's Avatar
Waldos
Waldos is offline
F 5 vin # help
Joe, Thank you very much. Just have to start brushing an cleaning to find the rest of the numbers. With this vehicle being a schoolbus and having a Superior body on it, I wonder how that all worked. Did they install the bus body at the plant, or did the truck frame go to the bus manufacturer where they put on the body and then back to the plant for the fenders and hood? This is interesting, thanks all for any help!!
Old 04-17-2012, 08:10 PM
harleymsn's Avatar
harleymsn
A bus? Oh, I believe it would have been shipped from the plant with the firewall, cowl and full doghouse and the bus body attached elsewhere. If it is a Superior body, they were manufactured in Lima, Oh, so chances are your F5 was built in Cleveland, Oh.
Old 09-12-2015, 11:36 PM
F4Bob's Avatar
F4Bob
F4Bob is offline
Old 09-12-2015, 11:37 PM
F4Bob's Avatar
F4Bob
F4Bob is offline
Originally Posted by F4Bob
Any idea what the prefix reads?
cruisetopdown
25
04-27-2012 07:01 AM
mhc18092
01-24-2012 08:10 PM
2011coyote
12-31-2010 07:44 AM
47coeman
1947 and Older Ford Trucks
27
06-07-2005 12:08 PM
bgbass
06-24-2004 07:38 PM
Quick Reply: Ford F-5 vin # help
