p0141 clarification
P0141 - HO2S Sensor Circuit Malfunction (HO2S-125) See DTC P0135
P0135 - HO2S Sensor Circuit Malfunction (HO2S-11) During testing the HO2S Heaters are checked for opens/shorts and excessive current draw. The test fails when current draw exceeds a calibrated limit and/or an open or short is detected. Short to VPWR in harness or HO2S.
Water in harness connector.
Open VPWR circuit.
Open GND circuit.
Low battery voltage.
Corrosion or poor mating terminals and wiring
Damaged HO2S heater.
Damaged PCM.
Wiring.
Damaged PCM.
Open VPWR circuit.
Open GND circuit.
Damaged PCM.
Wiring.
Damaged PCM.
Haroon
1997-2006 Expedition & Navigator
10-25-2010 06:08 PM
