O2 sensor problems
Old Jan 7, 2006 | 05:21 PM
chipdog4's Avatar
chipdog4
O2 sensor problems
Hello everyone, I have a 1996 F-150 Eddie Bauer truck with a 4.9 liter straight six in it and I am having a small problem with it. Earlier this week my check engine light came on and indicated that an O2 sensor was bad. It was the Bank 1 sensor 1 that was bad. I replaced that and then cleared that code and another one came up. This one was PO155 and it is Bank 2 Sensor 1 heater circuit manfunction. So I replaced it to, except that the check engine light came back on after I cleared it. I checked the wires by the O2 sensors and they seems to be fine. My question is what is wrong with it? Any help would be much appreciated.
Thank you.
Old Jan 7, 2006 | 06:01 PM
Popa Tim's Avatar
Popa Tim
Hi and Welcome to Ford-Trucks!
During testing the HO2S Heaters are checked for opens/shorts and excessive current draw.
The test fails when current draw exceeds a calibrated limit and/or an open or short is
detected.
Possible Causes:
Short to VPWR in harness or HO2S
Water in harness connector
Open VPWR circuit
Open GND circuit
Low battery voltage
Corrosion or poor mating terminals and wiring
Damaged HO2S heater
Damaged PCM
Honestly I would swap bank 1 & 2. If the probelm moves to bank 1 then its the O2 sensor. If it stays in bank 2 check the wiring, connectors, power, and ground. Lastly replace the PCM. I *think* we've had a few 96's with this same problem that turned out to be PCM's sadly.
I hpe this helped,
Tim
Old Jan 7, 2006 | 06:12 PM
chipdog4's Avatar
chipdog4
How do I tell if it is the PCM? I would like to follow a diagnostic chart to solve this problem but I do not have one.
Thank You
Old Jan 11, 2006 | 01:33 PM
chipdog4's Avatar
chipdog4
Took it in to the dealer and it DID turn out to be the computer. I guess the only thing that went wrong was the computer stopped sending the signal to heat up.
They want $349 for a rebuilt one.
My dad can get one in from his store for around $100. Not as bad as I thought it was going to be.
Thanks for your help, sir.
Old Jan 13, 2006 | 06:52 AM
Captbo2001's Avatar
Captbo2001
I had the same problem,,,, It turned out to be the PCM,,, got a rebuilt one from Advance Auto. Check engine light is off and stayed off.
a3mariner
Escape & Escape Hybrid
May 23, 2015 04:33 PM
JSTJ704
Jul 23, 2014 07:44 PM
MikeRizz
Mar 24, 2010 09:56 AM
hb1dp1b
Oct 29, 2002 04:17 PM
