Mushy brakes
Mushy brakes
I can pump my brake peddle when the engine is off and it will get tight. If the engine is running I lose that tightness and pumping wont bring it back. I pretty much have to push the peddle all the way in to start slowing the truck down. Air in lines or booster or what? This in turn makes it to where my stupid brake light sensor doesnt turn the lights on til I have it all the way down.
What year truck? engine? trans? Have you inspected the brakes otherwise? A functional booster will allow you to pump away the reserve vacuum with the engine off, making the pedal hard, because you no longer have its assist, then once vacuum is applied it assists you in your efforts to push it down, booster sounds good. either you have a leak, air in lines, rears out of adjustment, a bad master or a combination. Start with your rear brakes, they are often neglected, pull off the drums, make sure the wheel cylinders aren't leaking, axle seals aren't leaking, and the shoes are within specs and dry, if that checks out, spray it all down with brake cleaner, make sure they are adjusted and then check the rear hose isn't leaking then move to the front. Make sure no hose leaks, pads and rotors are within specs, calipers aren't leaking. Then check the fluid level in the master, make sure its full, if no ails are found thus far, bleed the brakes, you may have an abs bleeder to do too, if you have rear abs. if still nothing then probably a master. Since it does get tight and it doesn't seem to bleed down when off, I'd say probably not a master and more likely a rear brake issue.
I went and tested them again to make sure I was describing it correctly. What I found is it is rock hard when off with what I feel is average travel of the pedal. When On it definitely goes soft, doesnt make it to the floor but travels far before getting any real resistance. I put it in gear and at idle speed I cant stop the truck by pressing it down slightly. Not sure if that info changes anything or not just throwing it out there
My F350 was doing the same type of thing, turns out the brake booster (vacuum like yours) was bad. Steve83 calls it an over-active booster.
Here are a few threads with info:
Replaced [some stuff], brakes still suck.
Adjusting stop lamp switch - FSB Forums
The brake light switch is spring loaded, yes it needs some resistance to operate correctly. The issue you have is a little difficult to properly diagnose. If the pedal feel and height is good with the engine off then you are probably looking at a booster issue. If you pump the pedal a few times, engine off or on, then the pedal is solid then you have a hydraulic issue such as air in the lines or a master cylinder that is bleeding down internally.
I messed around with a similar problem for quite some time before finally figuring out it was a bad booster. Before tossing on any parts it is suggested to inspect all the brake components especially the rear brakes and all the rubber hoses. Never forget to cover the basics before going too wild with the checkbook and needless parts.
Like I said, I'm not trying to call you out or anything just kinda want to know how that's possible, it doesn't make sense to me, but then again I learn new things every day, and some of the stuff I already know, I find is incorrect. And like you say, the description is not exactly complete, is he referring to pedal effort, varying resistance in pedal effort, braking effectiveness vs. pressure applied, etc.
I do not have any issues with anything you have said. What I stated that you put in bold is exactly what I have found with hydraulic brakes. If you can pump the pedal a few times and the pedal "feel" returns to normal it's either air in the system or a leaking master cylinder. Perhaps I should have gone a little further to say the pedal may then start to drop again as you keep applying pressure.
We're on the same page IMHO, it's how each other is interpreting the statements.
Before I sent the OP down the bad booster bunny hole theory I wanted to make sure all the basics have been covered.
eatont9999
16
11-18-2011 12:31 PM
dynamic
13
11-21-2001 09:38 PM
