Sponsored by: Auxito
soft brakes?
Old Mar 13, 2010 | 11:27 AM
blacktop06's Avatar
blacktop06
soft brakes?
i have a 03 f150 crew with all disk brakes. i have replaced the master cylider but the brakes are still soft. i take me to stand on them to get it to stop sometimes than other times they fell fine. i sure i bleed them all the way out but not sure what else it could be. thanks for any help i get on this.
Old Mar 13, 2010 | 01:22 PM
Mawk's Avatar
Mawk
Could be a weak brake caliper piston or stretched brake hoses. Weak vacuum at brake booster, or leaking hose there.
Old Mar 13, 2010 | 02:25 PM
blacktop06's Avatar
blacktop06
wow were would i start.
Old Mar 14, 2010 | 01:52 AM
whitefordexplorer's Avatar
whitefordexplorer
start witht he easier ones first, like the vaacum at the booster. then work your way too the calipers.
Old Mar 14, 2010 | 06:43 AM
Joe Finn's Avatar
Joe Finn
I believe that if you open the system upstream of the anti-lock module, you need to pressure bleed the system. I don't think the old brake pump method will work.
Old Mar 14, 2010 | 11:17 PM
blacktop06's Avatar
blacktop06
ok how would i pressure bleed the brakes? sounds like a good place to start.
Old Mar 15, 2010 | 02:25 AM
whitefordexplorer
bring it somewhere they have a brake bleeding machine. Most Ford dealerships do, but its a little steep in the wallet. or see if you can rent one, and buy a sixer for a buddy to come help you figure it out.....
F100Lock
Oct 2, 2012 10:13 PM
hunting247
Aug 1, 2011 07:10 PM
nmichael
Jun 1, 2011 11:25 PM
dinikin
1997 - 2003 F150
Dec 15, 2009 06:23 PM
