Ford Rear Axle ID Question
Old 04-01-2012, 05:37 PM
1951flatheaddave's Avatar
1951flatheaddave
1951flatheaddave is offline
Hello experts,
I have an ad on craigslist looking for 9" center section so I can learn how to take them apart and rebuild them. I got a quote to have gears setup and was floored by how much shops wanted to do this.
Anyways...I had a guy call me and say he has a removeable 3rd member from a newer ford axle and is sure it isnt a 9".
He said it is from the 90's or even newer. What axle would have a removeable third member that isnt an 8" or 9"
He said he thinks its an 8.8 but I told him they have the removeable rear cover and the carrier is removeable from the back. He said this has the whole unit that removes from the front.
Thanks in advance, Dave
Old 04-01-2012, 07:23 PM
59JEEPSTANG's Avatar
59JEEPSTANG
59JEEPSTANG is offline
I believe Ford stopped using the 9 inch in the early 80's; however, places like Currie continue to custom make them to this day. Maybe it is not Ford, I think Toyota may have made a simalar unit....
Paul
Old 04-01-2012, 08:26 PM
1951flatheaddave
Yeah Im not sure, Guy said its from a Ford for sure. Did ford ever use a dana in anything newer? Did a dana have a removeable 3rd member?
Old 04-01-2012, 11:53 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,450 Likes on 1,397 Posts
I've never seen a Dana with a drop out center section like a Ford diff. Unless you have to travel for hours, it's worth a look to see what the guy has. At the very least, get some pics from the guy and post them here. If it is a Ford part, and if it is a drop out center section, it's either a 9" or an 8", which is a baby version of the 9". There will be some kind of Ford identifying marks on it. And it's older than 1984. After that, except for 3/4 ton and larger trucks, every rear drive Ford that I'm aware of has/had either the 7.5" or 8.8" rear cover type diff. And those have been around since the mid-late 1970's. You've certainly got our curiosity up.
Old 04-02-2012, 07:49 AM
1951flatheaddave
Just trying to think of all possibilities here....Did Ford use a removeable third member in the front differential of a newer 4wd maybe?
Old 04-02-2012, 09:37 AM
52 Merc's Avatar
52 Merc
52 Merc is offline
Not that I'm aware of. My guess is the seller is not 100% correct with his facts. It's either older than he thinks, or it's not Ford.
Old 04-02-2012, 09:45 AM
1951flatheaddave
He lives 15 minutes away and said he would take $20 just to get it out of his garage. I figured it was worth going to look at but was just trying to figure out what he has.
Thanks all!
Old 04-02-2012, 05:33 PM
1951flatheaddave
Its a Ford 8"
Is the Yoke interchangeable with a 9"?
Old 04-03-2012, 12:06 AM
52 Merc's Avatar
52 Merc
52 Merc is offline
I figured as much. Did you check to see what gears were in it? 8"ers have value, if it's in good shape. Even so, the case alone is worth at least $20. If it isn't junk, you could make a couple bucks on it.
I really couldn't say about the interchangeability. You'll have to check with someone with a Hollander interchange manual or a friendly Ford parts guy.
Old 04-03-2012, 07:19 AM
Aguas's Avatar
Aguas
Aguas is offline
9" thirds are easy to differentiate from 8" third members. The 9" thirds' pinion overhangs the 2 bottom holes that you use to attach it to the housing.
Aguas's Avatar
Aguas
Aguas is offline
Or he can always just take a tape to the ring gear.
Old 04-03-2012, 07:50 AM
1951flatheaddave
2.75 open carrier
Listing it on craigslist now, thinking ebay maybe but shipping might be a killer
ironmine
1999 to 2016 Super Duty
06-23-2008 03:57 PM
78'Ranger
07-23-2007 07:10 PM
ford390gashog
General Automotive Discussion
12-17-2005 12:53 PM
scott9320
10-24-2002 08:19 PM
54Guy
01-19-2002 09:15 PM
Quick Reply: Ford Rear Axle ID Question
