Im stumped 5.4 triton
Old 03-29-2012, 05:14 PM
stroken's Avatar
stroken
stroken is offline
OKay guys, I haven been on here in forever, and when I was it was in the diesel section, but Im a mechanic for a landscape company and I have this 2003 triton v8 with 115k on it, new trans in 2010 about 5-6k ago. This truck has me stumped
First off it runs fine no misfires, but it doesnt have power some times and some times it hits the rev limiter, it shifts all sorts of goof as if trans was slipping but fluid doesnt get hot, smell burnt. (ford oem trans when replaced) but it has like a "whistle" to it sometimes recently. and when you go to get into the throttle going down the highway it just like dies. and going up a hill from a strop, to the floor at 2300 rpm wont go any higher and does like 30 mph. Checked codes nothing. not one single code being found with my snap on scanner. performed a system check and still nothing. replaced fuel filter. no differance.
Any ideas???
Old 03-29-2012, 05:36 PM
shaneinga's Avatar
shaneinga
shaneinga is offline
Check the fuel pressure at the rail. I just went through something similar. Ended up being a fuel pump.
The dealer checked mine, said it should have 54 psi at the rail. Mine had 10.
Second pump on this truck, first one went at 75 thousand miles. It was run near empty to much and the pump stayed hot all the time. That is my theory on that one anyway.
The next pump was not a Ford part, I got it at a local parts store. I had too, I was towing a trailer to Florida when the original went out.
Here I am at 129 thousand miles and this will be the 3rd fuel pump this truck has needed, including the oem.
I would check for fuel, you would think if it were spark it would be showing a misfire in one of the cylinders.
Old 03-29-2012, 05:48 PM
kbsupercrew's Avatar
kbsupercrew
kbsupercrew is offline
Also check for clogged cat or cats
Old 03-29-2012, 06:02 PM
stroken's Avatar
stroken
stroken is offline
would these symptoms cause the crazy trans shifting?
Old 03-29-2012, 07:28 PM
shaneinga's Avatar
shaneinga
Idk, someone smarter than I will have to chime in from here.
When my pump was going bad, you could not get it to rev high enough to get to the next gear. I was beginning to think it might be a torque converter on mine. Or it did start to cross my mind when their computers were showing nothing was wrong with it, and it should be running fine.
Fuel pressure test I would think would be an easy thing to check and cross off your list.
Old 03-29-2012, 07:36 PM
kbsupercrew
Sounds like your in limp mode, check your fuses, f23 if i remember right, cats, o2 sensor wiring etc
Old 03-30-2012, 08:46 AM
galaxie641's Avatar
galaxie641
galaxie641 is offline
If this was replaced at a dealer it is under warranty for 12/12, I'd be taking it there for them to fix it.
brandon19
1997 - 2003 F150
03-01-2013 11:16 PM
zombiefan223
1999 to 2016 Super Duty
08-05-2012 03:10 PM
Hydroburke
Modular V8 (4.6L, 5.4L)
03-04-2009 01:28 PM
Ford-Trucker84537
02-26-2009 08:16 AM
raptor2020
08-31-2006 10:13 AM
Quick Reply: Im stumped 5.4 triton
