2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Soft brake pedal, firm on second pump. What's wrong?
Old 03-27-2012, 02:47 AM
ericjacobsen3's Avatar
ericjacobsen3
ericjacobsen3 is offline
I have spongy brakes on my '08 EL using about half of pedal travel. The second pump uses about 1/4 travel. My mechanic tried to bleed the brakes of any air but it didn't help. There is no leaking brake fluid. I'd like to get sorted out before heavy towing.
Anyone have an idea if this has to still be air in brake lines, master cylinder seal issue or something else?
Old 03-27-2012, 10:36 AM
berry1234's Avatar
berry1234
berry1234 is offline
Its been like this for years on ford trucks and expys. Some have it some dont. Search the F150 forums for more info.
Old 03-31-2012, 01:21 PM
critterf1's Avatar
critterf1
critterf1 is offline
You have air in the system somewhere.
Old 07-23-2012, 06:45 AM
ericjacobsen3
Soft brakes
I agree it would appear I have air in the system. However, I would think that air in the system would be soft on the second pump, not firm like I am feeling.
Agree?
For the alternate theory that "some of the Expy/F150 just have mushy brakes: I have a hard time believing a 1 million unit per year platform has brakes that cannot be made to work consistently.
I hate to say it, but it would seem to me that this is a bad master cylinder seal that doesn't push against the cylinder wall until extra pressure from a first pump pushes it to seal. Does this make sense based on the design of the master cylinder seals (no idea what they really look like)?
Old 07-23-2012, 10:33 AM
function12's Avatar
function12
function12 is offline
I have the same problem on my '11. Brakes work fine but sometime when you just press the pedal it will almost go to the floor very lightly. Then you press it again and it is rock hard.
Old 07-23-2012, 12:05 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
There is an air bubble floating in the system.....they can be stubborn, sometimes taking days to get out.....Highly recommend the use of a pressure bleeder (not the mighty mite, etc, a professional spec unit).
Now if....you hold your foot on the pedal and with the engine running is slowly drops, then you have a master cylinder issue.
Old 07-23-2012, 05:00 PM
ericjacobsen3
When you say it takes days to get a bubble out, do you mean the vehicle brakes are open for bleeding? If you mean just wait with the car in service, I have been waiting 8 months and nothing has chnaged.
Old 07-24-2012, 12:00 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
I remember my dad had a chev back in the early 60's, he worked for hours bleeding the brakes and could not get the "bubble" out, ended up taking to a brake shop, took them 3 days bleeding with a pressure bleeder in different methods befor finally getting the air out.
Old 08-24-2012, 09:04 PM
ericjacobsen3
My mechanic said it was the master cylinder and replaced it for $300. Not a bad price but it didn't fix the problem -arghhh!
Did anyone have this condition on an Expeditionn and successfully fix it with extensive bleeding (that I tried once)?
Old 09-05-2012, 05:59 AM
mrford60's Avatar
mrford60
mrford60 is offline
I have the same problem on my 07 expy and also had the same problem on my 07 sport trac that I got rid of. the sport trac I bought new and I had it back to the dealer 5 or 6 times they bled the brakes, replaced the front calipers, replaced the booster and master cyl, and did a tsb on the brake pedal, nothing helped. finally at 24k miles the rear brakes were worn down and I was about out of time on the warranty so I traded it in, but I thing that it might be something in the brake bias in the ABS unit. I think that we are stuck with the problem. I just bled the brakes on my expy and i dont think that it helped.
Old 09-19-2012, 07:08 PM
1Sic5Oh's Avatar
1Sic5Oh
1Sic5Oh is offline
Im not sure if your truck has it but our Navigators breaks are horrible if the pedals are adjusted all the way down. If you have the pedal adjustment than raise them more.
Old 08-27-2014, 07:31 PM
FordRick's Avatar
FordRick
FordRick is offline
I have been living with this soft pedal issue ever since I bought the Navigator new in 2007. Has anyone come up with a fix or aftermarket solution.
I have no idea why these were designed to be so soft with no easy way to adjust. There is a thread in the F150 forum that shows the brake booster rod being adjusted, solving the issue but apparently the rod has been redesigned.
Old 08-28-2014, 09:50 PM
ecyrbh's Avatar
ecyrbh
ecyrbh is offline
My 08 Expy does the same thing...What I believe the problem we are having is in our"Sealed wheel bearing assemblies"...I'm thinking that as the wheel rotates with the brakes not applied,lateral or any excessive runout with the rotor,causes the piston(s) to be pushed in slightly to move the pads away from the rotor surface,then upon the second application,the pads are closer to the rotor(s) surface causing a firmer pedal...If you have ever had a conventional tapered bearing fail or be out of adjustment,you get the same effect....Practically every sealed bearing I've ever "wiggled" on the car has some amount of play...Believe me,this condition can be drastically worsened towing a 27ft travel trailer,(especially in high wind conditions)...just my 2 cents.
Old 08-29-2014, 02:18 PM
FordRick's Avatar
FordRick
FordRick is offline
That sounds like a good theory. Best I've heard so far.
No wonder the dealer can never really improve the brake pedal feel. It sounds like too much slop in the system resulting from a lack of tight tolerances in design.
Dlasure2
10-12-2020 11:04 PM
vol1966
04-12-2010 02:16 PM
klr
16
02-02-2009 07:02 PM
Herman R
03-17-2007 02:06 PM
degdawgs
10-15-2005 10:00 PM
Quick Reply: Soft brake pedal, firm on second pump. What's wrong?
