Wood bed
Wood bed
So I found the link to make boards
https://www.ford-trucks.com/forums/9...ml#post9311541
can i use just 3/4 thick and still fit the outmost planks without the rabbet groove?
Hey Fnzen,
Doesn''t look like you were getting a lot of attention on your question
so let's bump it back up. I've got a 1950 F1 - We got our bed wood & sheet metal parts from Midwest Early Ford.
Early Ford
I'm not sure I follow your question but I'll take a stab - in our bed both of the last side boards in the bed had to be "adjusted" quite a bit to get them to fit. It was more work than you would think - certainly not plug & play.
Good luck over there & welcome aboard!
Ben in Austin
Early Ford
Ben in Austin
The wood is stepped down at the edges, along the sides, and at the back where a metal piece bolts in over the edgs. I didn't measure the step, but it appears to be around 1/8 inch....here's a pic of my boards before I put them in:
Here's what it looks like at the back:
I don't have any pics of the sheet metal cap installed in the back, but I think you'll need to notch the boards.
Dan
Dan
Cristobal Gomez
10-04-2018 09:44 PM
1950FordF1
09-19-2014 10:00 AM
