Fuel Pump Alternative?
Just bought an AIRTEX fuel pump for my 60 ford 292 Y-Block...it pumps like crap...decided to take it off to see something was wrong with it and found aluminum shavings inside one the ports,took the canister off and fuel filter inside doesnt want to stay on, the canister gasket is so swelled that you cant even put the canister back on.. Is there another mechanical pump that I can use that is better quilty....Right know Im headed towards a Carter elec. ....I will never by AIRTEX pumps again
Thanks Mark
Thanks Mark
Where are you pulling power from? Also, did you have to wire in a relay, or just connect straight to a keyed power source?
mikeboggess
12-26-2015 06:35 AM
stercorarius
04-07-2015 06:30 PM
zwinstead
05-27-2010 04:48 AM
