92 F150 FUEL PROBLEMS
A Friend on the rig here w/me had a problem with his truck.He pulled up left it idling,got back in and it would not build any rpms eventually died.it would only start w/starting fluid.I told him to check fuse for fuel pump,fuel filter,inertia switch,turn key on while listening for fuel pump running. is there something else i missed?
when you turn the key on can you here the fuel pump turn on? i've learned in the past to always carry spare fuel pump relays around $10.00 takes 2 seconds to replace kept me from being stranded several times, ether can be sprayed down the Throttle body of a fuel injected vehicle..
mkhmann
02-22-2017 01:37 PM
Hammer6950
11-25-2016 08:20 PM
mx495
09-17-2007 05:24 PM
