no voltage to terminals on injector pump 6.9
Old 03-21-2012, 06:47 PM
1983/84f350's Avatar
1983/84f350
1983/84f350 is offline
I have a 83 f350 with a 6.9 and ats turbo there is no power to the injector pump checked fuses all good fuel to injector pump but none to injectors suggestions
Old 03-21-2012, 06:58 PM
wbw189's Avatar
wbw189
wbw189 is offline
I had this happen with my '86. I found a blue fusible link by my blower motor that was blown. I did not find it until I folded the wire back on itself.
This was not the end of the road, though. I found the fuel heater on the line feeding the fuel filter shorted and keep blowing the fusible links.
Old 03-21-2012, 07:06 PM
1983/84f350
thanks i will check that !!
Old 03-21-2012, 07:08 PM
1983/84f350
I did find that broken wire on the fuel heater and fixed it today i did not know that was a heater
Old 03-22-2012, 08:15 AM
1983/84f350
I fixed the wires going to injector pump and now have some fuel to the injectors but it looks like only a few drops. I have 2 1000 cca batterys and cranked for a while but nothing. I did swap out the injector pump because the other was leaking. Its used off of my old motor. I also replaced the fuel line to the injector pump from the filter used 3/8 nobody had 5/16 i did not take off the top gear when i changed the pump any more ideas i really need this truck for my work
timb1776
42
07-22-2012 09:43 AM
Gknight
35
08-18-2010 11:08 AM
otter712
05-14-2004 09:37 AM
Quick Reply: no voltage to terminals on injector pump 6.9
