1997 f150 air intake
so im 16 dont have much money and i am looking for cheap ways to increase hp. my truck is an all stock 1997 f150 4.6L v8. my dad has a diesel and on diesels there is a air intake mod called the 6377 or BHAF all it is is an over sized air filter. do you think this would work on my truck
What he said, the stock factory intake is already a cold air intake and can flow twice the airflow that the engine can handle, so even a 50% plugged filter can meet your airflow needs at WOT. If your 16 and don't have much money, the best thing you can do is just keep the truck properly tuned to the factory specs, nothing fancy. This gives you the best power and economy.
As a general rule, if you was it cheap and fast, it won't be reliable. If you want it cheap and reliable, it won't be fast, if you want it reliable and fast, it won't be cheap. Your truck is already reliable, and has ok power,to get more without making your truck unreliable, you really have to spend some serious money. Your best option for power is a tuner. It won't work miracles, but it is the best bang for the buck, and it works with other modifications. Tuners are not cheap though, and off the shelf tunes are not optimal, so plan on spending extra on a custom tune.
The only cheep intake mod would be the gotts mod. Search for it on here.
It just takes the little nipple out that goes in the fender and replaces it with a piece of pipe thats a bigger diameter.
And like everyone said, it wont really give you more HP but will help a little in your throttle response.
BadAzzFordF250
1999 to 2016 Super Duty
24
03-14-2023 03:55 PM
Joe_Oh
1983 - 2012 Ranger & B-Series
04-09-2007 02:53 PM
