1994 F150 XL Need Info on Airbag light !
#76
JT I can tell you from personal experience you nee to remove the bed and just do em both while there. It looks intimidating as hell but once you do it it is REAL EASY. If you have a couple of buddies that can come over and help thats awesome if not I did it with me on one side and my wife and teenage son on the other. Biggest thing is be very careful where you grab on the one side so you don't buckle the bed under. Set it on some low saw horses and your good.
I know I am probably just too **** but when I did mine I just said screw it and replaced both pumps and both fuel sending units. Did not want to do it again. I also took it up and power washed everything I could reach while the bed was off. Lastly this is the easiest it will ever be to change that fuel filter that Ford screwed us all with when they hid it behind the gas tank instead of moving it 6" forward.
#77
1995 Ford F150 air bag light
Now, I know y'all had a discussion about this awhile back, but I'm new to this thread thing, and I need to pick someone's brain, the air bag comes on, even while driving, I've checked the horn, (works) don't have cruise control, (it's a 5 speed, w/ a straight 6) and I read it could be the clock spring, any one think they can help ?
