Airbag Light Fix
Old May 2, 2008 | 07:26 AM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
Airbag Light Fix
Well, here in VA we have yearly inspections. I had gotten a rejection due to a air bag light not going off. I talked to a local dealership tech. that i'm friends with and he told me to pull the passenger airbag switch (left side of the dash) and check that amber bulb in it. The bulb ended up being blown. All i had to do was cut the old bulb out and solder in a new one (a whole .59 cents for teh bulb). Just passing it on to save you guys some money from getting the stealership to run a test on the airbag system. Hope this helps
Old May 2, 2008 | 07:33 AM
mueckster's Avatar
mueckster
Good tip. Rep points given.
