Flareside fuel door(s) and tank(s)... options???
Old 03-17-2012, 02:33 PM
kedwinh's Avatar
kedwinh
kedwinh is offline
The writeup on there says you have to modify the sending unit to work with that tank.
Ford F834, take pics and let us know how you do the filler neck to a rear tank. Like to do something like that to mine, getting tired of the little 16 gallon tank.
Old 03-17-2012, 03:16 PM
klricks's Avatar
klricks
klricks is offline
Originally Posted by treese17
Lol that should be fun to figure out & can you use the old sending unit for that tank?
Yes you can use the old (or new) sender but you have to modify it per instructions that come with the tank.
Another possible problem though is that some trucks like my 4x4 have a skid plate under the tank that holds up the tank (not straps), so the skid plate or bolts would have to be modified as well. If you leave off the skid plate you would have to add tank straps.
Also the OP needs to enter his year and model etc and search to see if there is one that fits. The link I gave was for my '86 F150 EFI.
Old 03-17-2012, 05:57 PM
Ford F834's Avatar
Ford F834
Ford F834 is offline
Hummmm. Yeah. Mine has the skid plates. It's a 1986 F350 4x4 diesel. Autozone says this won't fit, and only has 19 gallon tanks for it... however, the cab donor (probably frame donor too now) is a 1983 F250 4x4 diesel, and they make a 38 gallon tank for it... I really don't know what the difference is, but it is a slightly different part number. Since I will be shortening the frame and other heavy modifications, I'm sure I can make one of these work. I will do a write-up when I get to that point, but it's a few months out at least. Main thing is that there is ~something for me to work with in terms of an aftermarket tank that will generally fit this style of truck... straps plates, modifications aside. Thanks guys!
FunInTheMud460
05-19-2017 08:23 AM
AbusedAmericanRust
09-30-2014 05:38 AM
56restore
07-01-2004 09:21 AM
LukeAdams
06-11-2004 09:50 AM
2ndmouse
15
12-25-2003 10:26 AM
Quick Reply: Flareside fuel door(s) and tank(s)... options???
