Back up light switch location
Is the back up light switch located inside the engine compartment on the steering column, looks like mine is missing. Is this what I need to get working? Thanks.
http://shop.advanceautoparts.com/web...RPSESWAMS_____
!970 f-100 360 c-6 automatic.
If it's an automatic, then it's on the column under the dash, just inside the firewall. If it's a manual, then it's on the transmission. On the 4speed it'll be on the upper housing, left front area. You will need to be either double jointed or pull off the tunnel cover to get to it.
The neutral safety and reverse lights are both controlled by 1 switch, on the column. the connector is a flat 4 prong (on my '72). The bracket also has elongated mounting holes for adjustment, and short mounting screws. The one in your link is for a manual trans.
This is it: NPD Wow, expensive!
Restoring American History | Mustang Parts | Camaro Parts | Chevelle Parts | Ford Truck Parts | T-Bird Parts | Firebird Parts
LMC, part #42
LMC Truck Parts - Page 129
LMC, part #42
LMC, part #42
LMC, part #42
Man your right about that price have to check junkyard next time I go. LMC isn't to bad so may have to go that route if I can't find one, thanks again!
ceetwarrior
25
11-27-2022 08:43 PM
Justntimeracing
23
04-17-2008 11:21 PM
79CSF250
04-24-2006 04:23 PM
