C-6 backup light switch?
Old Apr 23, 2006 | 01:33 PM
79CSF250's Avatar
79CSF250
My 79 f-250 camper special(460,C-6) needs the backup lights to work for inspection. The problem is that I can not find any wiring from the harness to the transmission,the only wires I can find go to the brake porportioning valve . The chilton manual shows the connection on the left side of the transmission behind the neutral safety switch but mine looks nothing like it. There is only a shaft with the outer lever being the kickdown lever and the inner being the manual shift lever. Could the neutral safety/backup switch be missing or could it be located somewhere else? Is there a difference between the camper special transmission and a normal transmission?
Old Apr 23, 2006 | 04:35 PM
tjc transport's Avatar
tjc transport
i ain't rite
the reverse light switch/neutral safety switch combo on a C6 is located on the shifter arm of the trans.there are 4 wires. two for nss, and two for reverse lights. I have never seen them any place else.
Old Apr 24, 2006 | 04:23 PM
rclarke's Avatar
rclarke
I don't remember the years but some of the older trucks have the neutral safety/back up switch on the top of the steering column under the dash.
