Door post bushing… Houston we have a problem…
Old 09-24-2022, 10:39 AM
TXwingnutt's Avatar
TXwingnutt
TXwingnutt is offline
Ordered some new door post bushings from Dennis C for 80-96 F-100-350. Couple issues, the mega washer won’t come off the post and the bushing actually seems a bit to long and wide…
anyone else run into this issue? Is there a decent work-around? I had duct tape on there but that doesn’t last long…
Old 09-24-2022, 10:50 AM
kr98664's Avatar
kr98664
kr98664 is online now
Here you go, several options in this thread:
https://www.ford-trucks.com/forums/1...nd-roller.html
Old 09-24-2022, 12:22 PM
TXwingnutt's Avatar
TXwingnutt
Your a boss Kr98664! Red PEX… why didn’t I think of that?!? I have a red and blue sitting around already!
since I made this post for no reason, I may as well add some pictures for folks like me who are visual…
If you don’t have a PVC cutter, you can use a fine tooth saw and a pair of adjustable pliers.
I used a wood chisel to pre-spread it a bit and then put it on by hand. What a quick easy fix! I will probably wrap it with tape just to keep it in place a little better.
** disclaimer: if you cut your fingers off putting the slit on the side using pliers and a saw don’t blame me… use your best judgment of your ability to handle a saw with one hand and be careful!
Old 09-24-2022, 12:33 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,683 Likes on 1,359 Posts
I have done this on several different vehicles, it will not come off. You saw how hard it was to spread and get on there. You can work it around so you don't see the slit and make it look a little better if you are worried about that. The weight of the door will be on the top surface.
Old 09-25-2022, 02:13 AM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is offline
Received 2,108 Likes on 1,796 Posts
Watch out telling him that his big head will get even bigger and he won't be able to get in his truck
Dave ----
Old 09-25-2022, 06:16 AM
kr98664's Avatar
kr98664
I used to have a convertible just for occasions like this. Got tired of washing bugs from my forehead, though. Finally got my own squeegee so I didn’t have to keep using the ones at gas stations. Didn’t really matter much, however, as I kept having to stop for fuel. The excess wind resistance did a number on fuel economy.
Finally found a better solution. I just create a fiasco, such as my recent ignition timing debacle. Quickly shrinks my noggin right back to normal size.
Old 09-25-2022, 08:25 AM
TXwingnutt's Avatar
TXwingnutt
I ended up rotating the slit to the cab side and putting a wrap of black duct tape around it, works well and doesn’t draw attention.
Old 09-25-2022, 05:38 PM
Rembrant's Avatar
Rembrant
Rembrant is offline
I don't know exactly when they changed, but sometime in the late 80's or early 90's they added a guard to the door post, and with those you actually can unscrew the post from the washer. They're easy to find at the junkyard and of course easy to remove. I swapped these on to my Bullnoses so that the bushings could be replaced more easily. THe Pex tubing works great too though, lots of guys have reported good results.
The following users liked this post:
OFP857
05-30-2022 09:38 AM
Bradz
03-24-2022 04:19 PM
77&79F250
20
09-28-2020 09:34 PM
crestfallinman
03-29-2012 09:53 PM
thekingofcows
19
02-20-2012 02:13 PM
Quick Reply: Door post bushing… Houston we have a problem…
