Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Performance & General Engine Building
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-09-2012, 10:06 PM
Uncle Grumpy Uncle Grumpy is offline
Garage is empty, add now
Uncle Grumpy is starting off with a positive reputation.
Yet Another SD EFI Rebuild Question
Hi,
I have bog standard '91 5.8l EFI SD 4x4 with C6 with only 40,000 miles. (ex-military Ambulance). I blew the head gasket so the engine gets a overhaul. Due to the weight of the body it needs a little help to get going.
To keep it within states emissions reg's it doesn't easily allow major modifications, so it will need to stay with the air and egr. My aim is to keep it SD friendly but try to help it along the road and still useful in 4x4.
My shopping list so far has Comp Cam 35-255-5, Performer heads 1.90 valves, long tube headers, 1.6 full roller rockers and whatever oversized standard shaped piston to fit the required rebore.
My question is if this setup is wrong or are there changes that can be made to help it further without major conversion (ie maf setup)
cheers
Tags
58, efi, ford, rebuild, sd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
