Extended Front Brake Hose Install?
Hey guys,
I need a little help on how to install my front frame to axle brake hose.
7" Extended Front Axle Hose
My truck is suppose to be a 77 F150. I don't have the hole in the frame where the brake hose would go through in the bottom part of the c - channel. I also don't see how the block can mount to the axle.
The factory front axle line had a piece of hard line going from the proportioning valve to a block on the frame and then from there a rubber hose down to the block/bracket that mounted to the axle.
The factory brake block mounted to the side of the pumpkin but there isnt a way for this one to mount like that. There's a bolt on the top of the axle I could get a longer one of but then the block is in the wrong spot for the lines that go to the calipers.
I could really use some help here.
Thanks
-Justin
Thanks
-Justin
The Terrible Blob
11-23-2013 08:46 PM
The_Builder
07-08-2013 10:01 AM
