E4OD not shifting into gear - challenging problem
I just ran the 351W I built through its initial 30 min break in period. So far so good with the motor. The transmission won't engage into any gear (forward or reverse), only the parking gear seems to work.
The background of this is that a couple of years ago I upgraded from SD to MASS Air and in order to get the MASS Air computer to work with an E4OD, I have one of these - Baumannator TCS. As far as I can tell this is setup and working properly. Need to wait until Monday to call them to get their thoughts on this whole issue.
I removed the transmission pan when the motor was out and I replaced some parts (reconditioning kit). What I did wasn't hard or complicated, I didn't go too far into the transmission. I feel I put it back together fine but I am no expert.
I also had a custom built torque converter. I filled the transmission so the dipstick is full but I am not sure if fluid has got through the entire system yet, I think I still need to add another gallon of fluid.
This is sort of a first shot in troubleshooting and a shot in the dark because I realize I have a custom setup but I think there has got to be a basic set of tests or something I can do to see what parts work and what parts don't work.
Anyone?
Anyone?
So far things seem to be fine with the motor and the tranny is still taking in some fluid but I ran into something that made want to stop and see if this is right.
My first issue is that I don't know 100% how much fluid is in the tranny but a good guess is ~3.5 gal. It's taking in fluid but not as fast and it is shifting into all the forward drive gears. I haven't yet moved the truck under the power of the transmission because when I shift into reverse, I hear a noise like metal rubbing so I shut everything down right away.
I just didn't want to proceed if this doesn't sound right.
Yeah, something is wrong where I don't want to push it. I wouldn't consider this a major issue, I was planning on having it rebuilt anyway (it can't handle the power of the motor). Just need to do it sooner than later. It's just money, right? I mean this is my Ford we are talking about here
Thanks for the help.
77 steve
31
02-10-2024 11:02 AM
latechbanjo
18
08-16-2016 08:29 PM
davro37087
07-24-2015 02:44 PM
Skandocious
10-03-2006 12:56 AM
