really need help
really need help
so sometimes when i drive my break pedal goes soft. i cant figure out why. and usually its at the moments i need them the most. when i hit my break pedal and theyre working fine it sounds like air is leaking out of somewhere a "psssst" noise. now i dont know if it is suppose to do that but i sure as hell know my break pedal shouldnt hit the floor sometimes. any ideas? thanks!
A bad diaphragm in the vacuum booster will make the wooshing sound also, but typically makes the pedal get hard not soft. When the pedal gets soft does it just go to the floor? My old buick does this when low on brake fluid, has a couple leaky cylinders. So i guess start in the most obvious spot and check your brake fluid if you havent.
Bob10
09-25-2017 11:33 AM
hawncase
10-08-2012 06:29 PM
snaponprofile
33
10-14-2010 12:31 PM
cr506
18
04-08-2010 08:16 PM
