Boost fooler and SES light
Ive had a boost fooler on my truck for over a year or so now but Ive noticed that at WOT making 27 psi of boost I still get an SES. I know that it is pre set at 22-23 psi. I cant remember how to adjust it. It has a *** on it to twist left or right. If I adjust it will it make the light stay off? The SES light shuts off after about a minute of normal driving
Sounds like it has lost the initial setting. Usually a regulator will limit the pressure more if you turn it counter clockwise.
You should be able to hook it up to a compressor and put a gauge on it. Then set it to 22 psi.
Or, just install one of these:
Riffraff Diesel: OCR - Overboost Code Regulator
Stock boost is 15-17 psi, DP makes there tunes so it doesnt trip the SES light or defuel as far as I know. I would imagine it would start defueling somewhere around 21-23 psi.
I wish I had access to AE to figure this out for sure, one day Ill buy me one. So my HPOP is mostly to blame at this point without having AE then isnt it?
DieselFuelOnly
11-29-2005 09:58 AM
greenhedhntr
01-27-2005 03:33 PM
