O.B.A. boost ses light
Old Sep 1, 2010 | 04:20 PM
wuttrd's Avatar
wuttrd
how much boost does the O.B.A. fool the pcm to not have a ses light. boost went to 30 today passing a dodge, ses light came on for a minuet or so then went off. will a disconect of the batterys cancle out soft codes?? thanks for the help.
Old Sep 1, 2010 | 04:24 PM
PaysonPSD's Avatar
PaysonPSD
An OBA should not pass more then approximately 22 PSI.
Not sure what codes may or may not clear by disconnecting the batts.
Old Sep 1, 2010 | 04:45 PM
wuttrd's Avatar
wuttrd
oba
thank you. guess i will try to keep it under 22 lbs boost.
Old Sep 1, 2010 | 05:06 PM
PaysonPSD's Avatar
PaysonPSD
Yeah, Right.
Why not install an OCR from Riffraff Diesel?. Or adjust the OBA you have.
I have an OCR and it works like a charm.
Old Sep 1, 2010 | 05:53 PM
Izzy351's Avatar
Izzy351
The OBA comes set to ~21psi. I tweaked mine a little (it's VERY sensitive) to work better with my tunes.
Since the SES will clear on its own after like 2 mins -- you shouldn't have to disconnect batteries, unless you just want the old codes cleared out of there...
Old Sep 1, 2010 | 08:12 PM
wuttrd's Avatar
wuttrd
thanks guys mine is set at 22.
