1990 F150 will not start has gas to full rail
Is there a relay that tells the injection ports to open , etc? 1990 f150 stright six auto, 2wd, duel tank with EFI.Will not start. Have power and is turning over but will not fire. Gas pressure good at fuel rail and fuel pumps both turning on at key turn on BUT stay on which I figured that relay went bad in on position? There is spark to the plugs and when gas is introduced into the throttle body ? it will fire up and run until the gas dissipates. Anyway any suggestions. Have not got any codes yet need test comp. Also if the EEC relay was bad the fuel pumps would not turn on, is that right?
So X2 for what subford posted above.
A quick test to determine if the PCM is at fault, most likely, or the Fuel Pump Relay is stuck in the On position is to disconnect the PCM then cycle the key On. If the pump turns on then you have a bad relay. If the fuel pump does not turn on then you have a bad PCM.
I agree, thanks!
In bold is your key symptom. Usually this indicates a bad PCM. The fuel pump should turn on for a few seconds, then shut off whenever the key is turned to the Run position.
Most of the time when the fuel pumps run all the time with a bad computer then the computer will not ground the fuel injectors. This will allow it to start and then die on starting fluid but it will not start with the injectors.
However if you set along enough with the key on sometimes the pumps will stop and then the engine will start right up.
I may have been running the truck for quit some time with the pumps running all the time not at the same time but the one that has been selected. So If I change my PCM I may have two correctly working pumps but will it start and run. Is it that the computers just give out eventually and mine finally died?
That's just what happened to mine on Saturday. Being in the electronics field I found all 3 caps (2 - 47uf 16v and 1- 10uf 63v) on an Ethernet and modem computer card. I robbed them to fix my ECC/PCM computer. One leaked so bad I repaired a corroded PCB track. I was fooled into thinking it was the pump and changed it but to no avail. Anyway with 184k on that pump i was worried it would go out soon. No more worries.
dernst
04-10-2009 09:12 AM
