Stumped.... Need help
Old Sep 5, 2012 | 07:25 PM
nickkennett01's Avatar
nickkennett01
Ok so here goes.. One day I trid to start my truck, 94 b3000, and dont catch it on the first try, as in I start to turn it over built let go before it fires up. So I try to turn the key again and it just turns over without firing.. I wait a few minutes, try again, and it fires right up.. This didnt happen again for a while so I thought it went away.. Wrong... A week or so later I pulled up to the gas station, got out, pumped my gas and when I tried to start it guess what lol no start just turns over.. I've had the truck long enough to know how long I have to turn the key before it fires up and it wasn't happening.. So I sat patiently for a few minutes. Turned the key and it fires.. Now it's starting to do it alot more frequently. I have figured out a few things though. So if I get in and the CEL does NOT come on its not gonna start. If I turn the key off and on eventually it will come on and will start. Also when I turn the key and the light comes on I can hear the fuel pump prime.. No CEL no fuel pump. So my question is it a bad fuel pump or ignition switch or........... Honestly I'm stumped any help would be amazing
THANKS!!!!!!!
Old Sep 5, 2012 | 08:21 PM
87 XLT's Avatar
87 XLT
No CEL means the PCM isnt powering up. Your owners manual will tell you the location of the PCM power relay. Try changing it out.
What about the fuel gauge does it work when the CEL does'nt come on?
Old Sep 5, 2012 | 09:12 PM
87 XLT's Avatar
87 XLT
OOPS my bad, if the PCM is'nt powering up, the fuel gauge wont work either.
What does work with the key on?
Old Sep 5, 2012 | 09:19 PM
Hank85713's Avatar
Hank85713
have you checked/changed your fuel pump relay lately? Sounds more like the relay than anything else. Dont know about mazdas, but this was a problem with the ranger.
Old Sep 5, 2012 | 10:27 PM
critterf1's Avatar
critterf1
Possible faulty/failing EEC relay.
Old Sep 6, 2012 | 10:40 AM
Rags's Avatar
Rags
Had the same problem with my 94 .. it was the EEC relay .. if you have a/c try swapping the two relays as they are the same. see if that helps your starting problems .. they are located in the power distribution box under the hood next to the battery.
bebeard
May 16, 2014 04:51 PM
9902ford
1997 - 2003 F150
16
Jun 4, 2013 06:20 PM
super fly
42
May 6, 2013 11:31 PM
speed
Feb 12, 2012 01:24 PM
car36
Jun 19, 1999 11:15 PM
