Vibration
Vibration
OK pulled up to stop at a stop sign and my '08 made a bad scrubbing sound, just like the breaks being gone and the rotors scrubbing. So I took it in to a brake shop and they said the brakes were not bad. I went ahead and replaced them anyway. Still made the bad scrubbing sound. About a day later I noticed a vibration when lifting off the throttle at highway speed.
I took the truck to the dealership and they said it was the rear end bearings. They claimed that you could move the drive shaft with your hand where it went into the rear end.
So they called back and said that all the parts inside the rear end were like new and that only the bearings needed replacing. Well a week later and after paying a $1,000 bucks they claim it's ready to go. The tech says that it still has a vibration, but that a caliper need turning and that the vibration is not related to the rear end issue. Well my questions is that it does have some vibration while braking, but today I started noticing the vibration while starting off and while slowing down even without touching the breaks.
If you have even hauled a heavy load or towed a good bit of weight and notice the driveshaft vibration when you first start off, it is a lot like that.
Also to point out that the 100,000 mile warranty doesn't cover the rear end, it's good for 65,000 miles, I have 70,000 on the truck.
Any help?
Any help?
Munkey
09-14-2003 02:58 AM
