04 F250 Pinion Bearing
Anyone have any recommendations for changing the rear pinion bearing on an 04 F250? My pinion seal was leaking so I changed it out. I did not put in a new crush ring, I measured the position of the nut before taking it off and went back to the exact position when I put the yoke back on with the new seal. Shortly after I started getting a howl in the rear end. I jacked up the truck and let it idle in gear and listened to the rear end with a stethoscope and it sounds like the noise is coming from the pinion bearing. Can the pinion bearing be changed without pulling the chunk out. If so how do I know how much torque to put back on the nut?
This is why I always recommend AGAINST the method of marking the nut and putting it back in the same place. There is no way to get the bearing pre-load correct other than shear luck. Now, the crush sleeve can be re-used, but it is best to add a small shim and crush it a little more, or at least tighten the nut and check the bearing pre-load to make sure you reach the correct spec.
What should it cost approximately to get a pinion bearing replaced? I called one shop and he quoted around $2100. He said he would not change the pinion bearing and warranty without rebuilding the whole differential. That sounds a bit steep, Jeeze, LOL. Hell I am trying to recover from changing my HPOP, Oil cooler, EGR Cooler delete, IPR and ICP sensor last week.
I heard an interesting take on differential oils this morning. I brought my truck into a local differential shop this morning to get my pinion bearing done. Small shop, but he does a ton of differential work and comes highly recommended. He ordered a kit for my truck and will changne the carrier bearings and pinion bearing while he is in there. This guy said he would "NOT" put synthetic oil back in my rear end. He said if I wanted to put synthetic oil back in my rear end he would not warranty his work. He claims that synthetics are not good for roller type bearings. He says that the oil does not stick to the bearings and gears as well as non synthetic and does not provide the cushion that non-synthetic provides for roller bearing. He said he changes out a lot more bearings these days since the start of using synthetic oil in newer trucks. He said that the places where he orders parts from recommend non-synthetic oil as well for the same reasons. I am just wondering if any one else has encountered this opinion. It makes sense and the guy seems very educated on the subject, but I am a bit skeptical. Hell I even have four bottles in my truck of mobile one synthetic 75W-140 and he said "please do not make me put that back in your truck". He has been building rear-ends for over 20 years.
There's lots of high mile differentials running synthetic. I think what could be the cause of the mechanic's thoughts is the synthetics have a much longer service interval, so if you aren't checking it and your fluid gets water/contaminants in it, it will be running longer contaminated versus a conventional oil that gets changed out every 20k. I'll be sticking with synthetics.
johnstonmatt77
06-14-2016 08:39 AM
Mistro
12-10-2002 10:25 PM
