Long cranking before start!
Howdy folks,
I have a 2006 F250 6.0 with 90,000 miles on it, changed the oil every 4000 miles, changed the fuel filter every 10 to 12,000 miles (currently have about 5000 miles on this fuel filter).
Here's the problem, went out the other morning to start my truck, it cranked over a lot longer than usual, then started abruptly, ran rough for about 2 seconds then seem to run fine. Ever since then, it has been starting the same way, I don't see any smoke at start-up, or at any other time while I'm driving (unless I'm passing a Prius ). When I'm driving, the truck runs fine.
If anyone has any suggestions, I can use the help!
Thank you!
Thank you!
A friend of mine had the same problem and he started adding automatic transmission fluid to every 3rd or 4th tank of fuel and he has noticed a big improvement. I wasnt having any problems with starting but have also started to do this and have noticed a big difference also!! Hope this works for you!!
I'm sorry, that's too funny. Also, check fuel pressure.
My '06 was cranking longer than usual before starting. A check of battery voltage during and right after startup showed that the batteries were at the end of their useful life.
A new pair of Motocraft batteries brought things back to where they should be. Battery degradation sneaks up on us. We do not notice the slight change in how long it takes to start our trucks or how fast the engine cranks over. Maybe a lot of the FICM failures we hear about are actually caused by weak batteries...
Lou Braun
Lou Braun
FICM voltage (test procedure is definately in the Tech Folder) should be 48V, never less than 45V. Even in the high 30sV the truck isn't healthy, and that can cause rough running and injector problems.
Main voltage can run into the 10/11s for up to the first 2 mins while the glow plugs cycle, but should kick up into the high 13Vs once the alternator starts charging the batteries. No matter how it sags, FICM V should stay at 45+V.
You can load test each battery separately to see how they're holding up, one of the two being bad can cause problems and they tend to die suddenly. I went from "A-Ok" to the starter not clicking in under a week, and I was watching all my volt on a gauge.
Hands down easiest way to check all this without running a multi-meter all under your hood is a ScanGauge: ScanGaugeII : Linear Logic - Home of the ScanGauge You can search up dozens of threads here that explain how to use it to check about 90% of what you need to watch on the truck, and if you put up readings from it it really helps all the tech-inclined guys pinpoint problems faster. It's cheaper than a single 2" gauge, and covers so much ground it really is a must-have.
Good luck with it
no offense to the other guys who posted on here but i'd load test the batteries individually first. if batteries are fine, then i'd check the alternator next. jus to be on safe side b4 i go check the ficm. process of elimination. most of the time, it may jus be the batteries. if getting new batteries, jus make sure they're over 850 cca
trevorrules
08-22-2014 02:26 PM
Maze
17
05-03-2010 09:48 PM
