C4 transmission linkage
I"m trying to put my sons truck back to original configuration as far as the transmission linkage goes. It has a c4 but the po had put in a floor shifter and I'd like to go back to original column shifter. I have the rod that goes from the column but the transmission end has me wondering. The truck is a 1976 f100 with c4 automatic transmission and a 390 engine. Anybody have a picture or diagram of how the linkage is setup on the transmission?
The linkage itself is simple. Just the rod between the steering column arm and trans shift arm.
Here's the generic illustration from the Ford parts catalog.
Click on the .pdf link to view, scroll to the bottom half of the page.
Also, here are a couple of pics of a C4 and C6 transmissions.
The C6 has an intgral bellhousing, the C4 bolts on.
Actually I"m not sure it's a C4. I have a 1987 F250 Diesel that has a C6 and figured the older truck and a gas burner would have a C4. I"ll have to go out and look at my truck and see if it's the same as the transmission in the 1976 F100 truck of my sons. I had a 1977 F100 or 150, can't remember which and had the transmission rebuilt when it lost reverse. Thanks Mike, that's the illistration I was looking for!!
No FE engine ever came with a C4 (including Passenger Cars).
1968/76 F100/350's w/360/390's, 1973/79 F100/350's w/460's, 1977/79 F100/350's w/351M/400: The only A/T available was the C6.
1978: C6 was optional in F100/150 302's for the first time. Prior year 302's were only offered with C4's.
Ford confusion: 1965/78 F100/350: Ford used the same G Warranty Plate TRANS code for all A/T's. One had to know which trans was available with what engine.
1979: G = C4 / K = C6.
You will probably also need the stud that connects the shift arm to the linkage.
Here is a picture of the arm and stud that you'll need, ignore the idler pulley.
Lever assy., manual control
Fits 73-77 F100-350 2WD
D3TZ-7A256-C
Green Sales, Cincinnati, OH has 1 (800) 543-4959
Antique Auto Arlington, Arlington, TX has 1 (817) 275-2381
Stud, Trans gearshift to connecting rod adjusting
73-up E-F100-350
JST Automotive, Lebanon, TN has 1 (615)443-3086
D3TZ-7A256-C
73-up E-F100-350
brider
06-06-2012 05:01 PM
1972fordf-100
09-23-2008 06:22 PM
1968, 19731979, 1978, c4, c6, connecting, f100, linkage, number, pan, part, pics, transmission, transmissions, truck
