2006 F150 2wd to 4wd
Old 02-18-2012, 01:55 PM
SHANE_2's Avatar
SHANE_2
SHANE_2 is offline
I posted this on another forum and the only Advise I got was to buy another truck!!!! Hoping to get some real advise on this.
So I have an 06 F150 supercrew lariat 2wd. Its nicely loaded and I like the truck. Bought it in Oct. and got a good deal. Otherwise I would never buy a 2wd. Anyway, I have been doing some looking and a little research, I want to make it a 4x4. Has anyone else done this? It appears the frames are the same, as well as the control arms and front suspension. As near as I can tell I just need to swap the transmission/transfer case, add the front diff/axles etc. and a 4wd switch. The harness is there and theres an option in the GEM to tell it if its 4wd or not. Any suggestions?
Also I have some mechanical ability and a lift in my gargae at the house!!!
Shane
Old 02-18-2012, 06:58 PM
j.grif's Avatar
j.grif
j.grif is offline
get a donor truck to get all the parts from, that would probably be the cheapest way to do the conversion, maybe a rear end total from an insurance comany or salvage yard, in addition you would see how a part came off and would save a lot of guessing.
Old 02-18-2012, 09:36 PM
hydro_37's Avatar
hydro_37
hydro_37 is offline
anything can be done with enought time and money
it will require ALOT more parts then what you listed
Old 02-19-2012, 11:08 PM
DieselBeast01's Avatar
DieselBeast01
DieselBeast01 is offline
I'm going to be the one to say it...Trade it in/Sell it and buy another truck.
It will require quite a few more parts than you listed and will be a pretty large job. I wouldn't tackle this myself, but some people have more patience and know how than me and could pull it off. In the end, it's all up to you.
Old 02-20-2012, 06:38 AM
danorules's Avatar
danorules
danorules is offline
X2 sell it. Too much work and once you are done you will be chasing gremlins the whole time you own the truck
Old 02-20-2012, 08:00 PM
Louie3's Avatar
Louie3
Louie3 is offline
I only see this being practical on older trucks the new ones have a lot more to mess with
Old 02-21-2012, 11:44 AM
skunkoffroad's Avatar
skunkoffroad
skunkoffroad is offline
I have converted a few older trucks and even with the solid axle and all the major parts paid for ahead of time the damn conversion almost nickel and dime me to death. with that being said if the front control arm brackets are the same and I think that's a big if then it is possible. I'm sure you'll need to Change or reprogram The ecm and transmission control module. If you go through with it please let us know how it goes I think we would all learn something along the way.
Old 02-21-2012, 12:08 PM
jr105's Avatar
jr105
jr105 is online now
I agree with j.grif's earlier response that buying a wrecked donor truck for the parts would be the way to go if you are going to do this.
Old 02-21-2012, 08:25 PM
hcbph's Avatar
hcbph
hcbph is offline
Conversion
If you're absolutely bound and determined to do this, then find a rollover that otherwise is good. The your body and slap it onto that frame. salvage all the required electronics and be done with it.
Even doing this is going to be alot of work. If you like your truck, keep it. If you want a 4x4 then find something to work on and build up. There are alot of half finished projects out there, why add another one to that list.
roystondrake
06-04-2016 07:56 PM
Riskyguy
06-28-2011 04:05 PM
chris5301
1997 - 2003 F150
12-29-2009 04:25 PM
LoxBoy
09-09-2008 07:43 PM
f150hotrod
06-14-2005 12:03 PM
Quick Reply: 2006 F150 2wd to 4wd
