rear sump oil pan question
Old 02-17-2012, 07:54 AM
moejr's Avatar
moejr
moejr is offline
Received 1,016 Likes on 480 Posts
I have a 68 302 and want to change the oil pan from a front sump to a rear sump, a spectra oil pan #FP01A looks to be the one I need but shows no provision for the dip stick. Any suggestions would be appreciated. Thanks.
Old 02-17-2012, 04:02 PM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is offline
You will have to use a dip stick going through the side of the block, found in the later models. Other than that, you may have to find or modify a pan to accept a dip stick through the side.
Old 02-21-2012, 06:14 AM
moejr's Avatar
moejr
moejr is offline
thanks, looks like a pan from a 81 E-100 will work, it has a provision for a dip stick on the side.
Old 02-23-2012, 03:02 PM
Archion's Avatar
Archion
Archion is offline
That looks to be the FP01B.
ecat
Old 02-27-2012, 05:58 AM
moejr's Avatar
moejr
moejr is offline
thanks for your reply, i ordered one (FP01B) form Amazon and recieved it last Friday.....nice well made pan, now i need to find a dip stick that will screw into the side.
Old 02-27-2012, 01:23 PM
Archion's Avatar
Archion
Archion is offline
Not the cheapest, but an option...
Lokar: Engine Dipsticks Part Numbers
Old 02-27-2012, 01:35 PM
moejr's Avatar
moejr
moejr is offline
thanks Archion, i'll check it out..... checking around the web and found FORD pt. # E3ZE-6750-CA should work, i'll check w/local dealer and see if they still carry them.
kens65fb
05-12-2018 02:14 AM
tim.beery
02-14-2012 01:54 PM
lm987
29
08-09-2010 08:55 PM
Firemudder
04-21-2007 07:58 PM
solid dakota
07-19-2004 04:22 PM
Quick Reply: rear sump oil pan question
