same old question
Old Feb 26, 2012 | 08:18 PM
craziejoker's Avatar
craziejoker
same old question
I am building a 1964 F100 short box for my dad. I have read on this site quite a bit here, and I have searched but not found the answer I am looking for.
I have access to two engines in my budget. I know both ran, and I plan on just converting to carb, and some mild bolt ons, maybe a cam.
Engine one is out of a 00 mountneer 5.0 and engine two is out of 86 E150 5.8.
I am looking for part access(like header options and cams) and horsepower for the dollar. I am not building a drag truck for pops, but I want the truck to let's say, be motivated.
Thanx
Old Feb 27, 2012 | 12:31 PM
bfbronco's Avatar
bfbronco
id go with the351w more power as is and more potenta later! ive had both and thrers not much mpg but a lot better performance
Old Feb 27, 2012 | 07:18 PM
Conanski's Avatar
Conanski
All stock the 2k Mountaineer 5.0 is the better choice, 9:2 CR with heads that flow well enough for 300+ HP and a factory roller cam. This motor just needs a cam and exhaust to be a real screamer.
In comparison the '86 5.8 is a turd, 8.5:1 CR thanks to smog heads with hugh 69cc chambers and a tiny flat tappet cam. This engine has more potential due to it's larger displacement but you'll have to replace the whole top end to see it.
Old Feb 27, 2012 | 07:49 PM
craziejoker
Thanx conanski. I kind of knew the answer, but I needed confirmation. If I can save some cheddar on the engine and make the sameish horsepower, that frees up $ for more goodies.
Old Feb 27, 2012 | 09:25 PM
baddad457's Avatar
baddad457
One more option: take the heads off the 5.0 and transplant em onto the 351. Swap in a better cam while you're at it and top it off with an RPM airgap intake and Holley 80783 carb.
Black Ford XLT
Jan 27, 2016 12:44 PM
cchimuk
21
Feb 23, 2013 03:33 AM
reed1951
Oct 1, 2006 08:42 AM
89BroncoXlt
15
Feb 4, 2003 05:45 PM
idfliers
May 4, 2002 10:30 PM
