'64 F100 Cruisomatic ID Tag Info
1964 F100 Cruiseomatic ID tag info.
PBW-F = 1960 Ford-O-Matic 3 Speed Transmission / Parts List A70.1.
As original: 1961/64 F100/250 with FX Cruise-O-Matic: The rectangular ID tag is located on the left (drivers) side, under one of the bolts that retains the trans pan to the case.
numbers
do you perchance have one of these charts
that goes back to '60?
Ford Truck Automatic Transmission Application Chart '64-'72 - FORDification.com
i will get out there tomorrow with my trusty plastic scraper
and look for my tag.
Have A Nice Day!
Have A Nice Day!
numbers
while i've got you on the phone.
his truck transmission cooler is still hooked up correctly.
mine they butchered it to run lines up to later radiator bottom tank transmission cooler too.
what's the other steel line on same side as truck cooler
that on his is in 'from the factory condition' and it
heads back and then up at slight angle?
looks like from there it had rubber piece of hose on end
and then maybe another steel line going somewhere.
Have A Nice Day!
Have A Nice Day!
Fordification's info is from the 1964/72 Ford Truck Parts Catalog / Text-Section A70 / Pages 2 & 3.
See post #2 for the other truck parts catalog info.
Both these catalogs are available on CD's from hipoparts.com.
Originally Posted by ALL AMERICAN BOY
numbers while i've got you on the phone.
It's 3:30 AM here in LA LA Land, so there's no way I'd be talking on the phone, except maybe to "Squire" Don.
You're not talking to me, because you don't have my phone number! I don't have your number either.
TGFSF
numbers
your chart in post #2 doesn't work as a link.
i think that's what the hold up is.
regarding the steel line.
let's go with this:
the truck transmission cooler uses the two lower fittings.
coming out of the top fitting up front
is my mystery steel line.
what is it?
'you got me hanging on the telephone'-Blondie
before you have another near heart attack
those are sayings or expressions.
all us heavy hitters in la use them.
Have A Nice Day!
let's go with this:
what is it?
Have A Nice Day!
Welowright
28
02-06-2017 09:17 PM
razor10000
10-03-2015 07:24 AM
