Decoding tag on middle chunk on a 1981 F100
Hey I'm Wesley . Can anyone help me decode a tag on the middle chunk. I have a 1981 F100 lwb truck . It has a 300 straight 6 ,3 speed with overdrive and 123,672 original miles. I am the third owner of this truck and I have to replace the axles. Im trying to decode this tag and some numbers and letters that are stamped on the middle chunk. I also don't know if they have changed out the rear end or anything like that. Can anyone help me with this . I want to thank you Gary for helping with the link you gave me , it helped a lot . Thank you again
Wesley - Good post. Except you didn't post the pic.
Having said that, I've taken another look at my Axle Ratios page and my Differentials page and realize that I didn't include the graphic on how to decode the rear differential tag. So, hang on a bit while I update one of them..............
EDIT: Well, you got it posted, but we can't read it. Let me get the info up so you can decode it yourself.....
Actually, the info is already on there here: Rear Axles - ???Gary's Garagemahal.
The problem is that I have a real mess with regard to rear axle info.
wasn't for sure it it was completely readable that's why I posted the letters an numbers below the picture in the order they were on the tag . Thank you guys for the help on this. Also have a question . K on the middle chunk close to the area where the tag is bottle and on the very front of the middle chunk where the drive shaft connects.. do those numbers and letters that are on the stamped on the middle chunk mean anything?
thank you so much Gary and thank you so much too franklin2. My last question is , I have a tag that is attached to the frame underneath the bed of the truck towards the front of the bed next to the cab on the passenger side. It has a bunch of letters and numbers but first part of the numbers are different from the VIN number but the last numbers are the same as the VIN. Also the second row of numbers I have no clue what they are. I have 2 pictures of it below. Do yaw know what these are.
K thank you so much gary
k thank you Gary . I will check them in the morning to see if they match. Does anyone else might know how to decode them or know of any link to decode this tag . I thank you Gary and thank you franklin2 and thanks to anyone else who might be able to help with this tag above . Yaw have a goodnight see yaw tomorrow and be safe and have a blessed night and day .😎
