Overhead console removal?
Old 02-10-2012, 02:37 PM
High Binder's Avatar
High Binder
High Binder is offline
Does anyone happen to know the trick to removing the overhead console? I went out and pried on it a bit looking for screws or clips but had to stop because I could feel that 'WTF' thing coming on and that usually results in broken parts.
Old 02-10-2012, 02:48 PM
bpounds's Avatar
bpounds
bpounds is offline
It just pulls down. I know it's scary, but it really is just clips holding it in place. Helps to wiggle side to side as you pull. Wiggle the console that is
Old 02-10-2012, 04:07 PM
High Binder
LOL! I'll just pull on it with a little more enthusiasm and if that doesn't work, I'll get the wife to lend a hand.
Thanks for the tip.
Old 02-10-2012, 04:22 PM
Teds's Avatar
Teds
Teds is offline
mine broke when i took it off....be careful pulls straight down
Old 02-10-2012, 04:32 PM
High Binder
Dang, that's what I'm afraid of. Were you able to repair it or was it trashed?
Old 02-10-2012, 05:04 PM
Teds's Avatar
Teds
Teds is offline
broke 3 tabs off bought new one....
Old 02-10-2012, 05:31 PM
pmoney1983's Avatar
pmoney1983
pmoney1983 is offline
What is the reason you dont want it anymore?
Old 02-10-2012, 06:09 PM
High Binder
My compass reads about 270degrees off so I'm trying to get into it so I can fix the compass chip and do a write-up so everybody else can see how it's fixed.
Old 01-09-2013, 08:45 PM
walker williams's Avatar
walker williams
walker williams is offline
upper console
Once you have removed the upper console, can you replace the LED's that show compass, gas mileage etc?
Old 01-09-2013, 09:46 PM
Beachbumcook's Avatar
Beachbumcook
Beachbumcook is offline
Got Diesel?
There is another thread about this very topic that was started today (console removal).
It is a common problem for the circuts to come loose (soldered connections come loose internally over time).
The other thread had a nice write-up with links to pictures.
As well, there was a link to a company that you can send the unit to and they will repair and test it for you for around $35.00 (seems well worth it to me).
Good luck,
Old 01-09-2013, 10:42 PM
Z-MAN's Avatar
Z-MAN
Z-MAN is offline
https://www.ford-trucks.com/forums/s...d.php?t=441601. $16.00 at radioshack for a low watt soldering pen and a steady hand is all it takes. read post with red links and your good. by the way was my first attempt at soldering anything, just make sure to not cross any circuits with. the solder.
Old 01-10-2013, 07:57 AM
Whitey Ford's Avatar
Whitey Ford
Whitey Ford is offline
FTE-Spread The Knowledge
David can repair your Overhead Console for $22.00 with lifetime warranty.
http://item.mobileweb.ebay.com/viewi...id=19289165983
David Ruberg 507-429-4489
Never have to worry about it again OR spend anymore $$. Just a thought!
Old 01-10-2013, 09:06 AM
Sark's Avatar
Sark
Sark is offline
Thumbs up
Here's another site. I used them for my console repair & they had a quick turnaround.
FORD F-series Overhead console kits and Parts
Old 01-10-2013, 09:08 AM
Beachbumcook
Got Diesel?
Ford F150 F250 F350 Super Duty Temperature Compass Overhead Console Disp Repair | eBay
Now this is what I call service at a reasonable price... think I will try taking off my overhead console.
Kdr358
04-04-2012 04:56 PM
emd160
6.7L Power Stroke Diesel
12-29-2011 07:54 PM
hdman6
02-27-2009 12:15 PM
bkcowboss
05-04-2008 04:42 PM
D2EBMA
1997-2006 Expedition & Navigator
03-19-2004 01:25 PM
Quick Reply: Overhead console removal?
