Removing overhead console '00 EB
Old Mar 15, 2004 | 06:24 AM
D2EBMA's Avatar
D2EBMA
I want to hard-wire my radar detector using the power that feeds the rear window switches in the overhead console. Can someone tell me how many clips, bolts, screws, Jezus clips, etc hold that console on? I only saw two on my first inspection in the area that becomes visible above the sunglasses holder.
Thanks!
Old Mar 15, 2004 | 04:13 PM
D2EBMA's Avatar
D2EBMA
Anyone? Bueler? Bueler?
Old Mar 15, 2004 | 09:15 PM
buzzard's Avatar
buzzard
1 Remove the screw from the inside of the sunglass storage bin.
2 Release the three clips (2 up front and 1 toward the rear) and slide the roof console forward and then down.
3 Disconnect the electrical connectors.
Old Mar 16, 2004 | 07:49 AM
FarmLaw's Avatar
FarmLaw
Buzz's got it down.
Sorry I didn't get back to you sooner...had a bad/busy weekend.
Let me know if you can't find the wires.
When you put it back up, kind of in the center of the console there's a cone shaped plastic doo-hickey that has to line up with a hole in the ceiling mounting bracket. Make sure you get that lined back up...
Old Mar 18, 2004 | 02:30 PM
D2EBMA's Avatar
D2EBMA
FarmLaw -
I've got the console off, but can't find any wire that carries power... the only common wire I've found that goes to everything on the console is green/orange... is that what you tapped into?
Old Mar 18, 2004 | 02:36 PM
FarmLaw's Avatar
FarmLaw
On mine, I tapped into the power wire for the rear vent window switch. It is keyed 12V on the delay relay (turns on when you turn on the key, stays on until the key is off AND a door is open). I can't recall exactly what color it was...but I remember that it came down at the middle of the console, right over the vent window switches. I tapped into it right above the switch.
Old Mar 18, 2004 | 02:39 PM
D2EBMA's Avatar
D2EBMA
Thanks - I tried every lead except the ground but couldn't seem to get power... going back out to give it another try... there are about 8 wires heading into each of the blocks above the rear vent switch.
Old Mar 18, 2004 | 02:54 PM
D2EBMA's Avatar
D2EBMA
Nope - can't find a wire that's carrying juice. There's a block above the switches, but tapping them individually gives me zero result. Frustrating.
Old Mar 18, 2004 | 03:35 PM
D2EBMA's Avatar
D2EBMA
Finally put a meter on the whole harness and it would appear that with the exception of the dome light, everything up there is low voltage. I don't know if they changed something from 2000 to 2001, but there isn't 12 volts anywhere in that console. FarmLaw, you lucked out... I'm going to have to snake down to the fuse box. Bummer.
Old Mar 19, 2004 | 12:50 PM
FarmLaw's Avatar
FarmLaw
D2,
Perhaps I didn't luck out. I was just working with a testlight, and didn't try the ol' multimeter. It is possible that I'm tied into a low voltage circuit...as I doubt that would change in one model year, although it is possible. Maybe my detector just works fine with low voltage...
Old Mar 19, 2004 | 01:25 PM
D2EBMA's Avatar
D2EBMA
That'd be something... it wasn't as bad as it could have been - snaked the wire along the headliner, down the pillar and into fuse #6 (accessories, mostly). The first part of the exercise took better than an hour. Wiring it to the fuse box - 5 minutes. Live and learn.
