Goodyear Badyear
Goodyear Badyear
Found, what looked to be, tranny fluid under the front of my van this morning. I just had asked the local Goodyear service center replace both of the original hoses to the tranny cooler (they're old and the clamps are worn out) so I was a tad concerned.
When I shined my flashlight in through the front grill imagine my surprise to see only one new hose with the other still soaking wet with fluid.
The bill came to $81 dollars. $30 for the hose and $51 for a half hour of labor.
Careless... stupid... take your pick.
When I bought the van I knew there was an issue with one of the brake lines leaking so it was towed 80 miles to my home town and, since they are within walking distance of my house, to Goodyear.
While the van sat there for three days awaiting service on the line(s) I found the leaking tranny issue and, since it was there and since I had only three days to get the emissions done or my 10 day temp plate would run out I told them to do it. No big deal, I assumed. They had it up on the lift in their nice warm garage anyway.
I've learned my lesson and, with the help of the generous and knowledgeable folks on this forum, I'm confident all future work will be expertly done by me.
No more adversarial much of what's been posted here before. Such a comment is probably due their in-person experience and NOT another forum member. Huge, huge difference there!
Goodyear the manufacturer might indeed make many a good product however the retail service outlets are either company-owned or franchised stores that undoubtedly have very little to do with the manufacturing wing. I dare say the hose division has almost nothing to do with either the tire brand as well.
The disparity in service has everything to do with the ownership and not the name out front. ASE certified mechanics are as prone to mistakes or shoddy work regardless where their tool boxes are parked---management makes all the difference. So far this OP has had a bad experience with the outlet so its safe to say they're not that well managed.
Scooter time to find another mechanic shop---the faster the better!
Good chance "the local Goodyear service center" employs ASE Certified techs. Goodyear enjoys a reputation for making excellent specialty hoses.
The goal here is to be less adversarial than before.
blageurt's question "Why would you even consider taking your truck to those clowns ?" seemed to disparage every "local Goodyear service center" w/no regard to "ownership...management". A complete rejection of your theory.
If local Goodyear service center ownership/management actually did the repair work there might've been some basis to examine IF it "makes all the difference". It's easy "to find another mechanic shop" in Yellow Pages, but attempting to evaluate the ownership/management is likely a more daunting task than the mechanical issue.
IMO, if Scooter is "confident" he should be encouraged, by other FORD Truck Enthusiasts, to at least try doing "all future work" himself. And not just be relegated "to find another mechanic shop---the faster the better!".
Mine was leaking, I have the old Tridon screw clamps, I took my screw driver and cinched them down, if that doesn't work, the hose end is galled, cut 1/2" off, reconnect and tighten, end of story. My van is a 99, it was doing this 5 years ago and hasn't leaked since, if it doesn't have a screw clamp, put one on it.
F150daniel
05-27-2003 09:09 AM
