Cam Phasers!!!!!
Cam Phasers!!!!!
I have an 05 Expedition that is needing cam phasers and I can't seem to find them anywhere but at a Ford dealer. If anyone can help me locate them for cheaper than $248/each I would greatly appreciate it. I also need the wedge specialty tool as well. I know there are some guys on here that said they got them for under $200 so your input and info would be nice!!! Thanks in advance!!
Jeremy
Jeremy
HTH
Well i think i talked the dealer into buying the phasers for me. He said to bring it in and he would have it fixed in two weeks. Well two weeks is too long without my vehicle so i told him to get the parts and i would do it myself. I have already thought about doing the lash adjusters and rockers while in the engine. Guessing i can get those from the places yall suggested as well?? What about the wedge?? I will need that as well. Anyone out there that can loan it to me for a week or so?? Thank yall for the input and advice!
Jeremy
Jeremy
You should be able to do it in a weekend no problem. I've done a half dozen or so of these and it ususually takes around 5-7 hours. The worse part of the job is getting everything apart so you can get the valve covers off.
The only specialty tool you need is the wedge. You will, however, probably have to drain and recharge your AC. Just be sure to wedge the tool in firmly to hold the chain and make sure to mark the chain on one of the two timings marks and reinstall the same way when you do the phasers.
If you search this forum, you should be able to find several topics discussing this proceduresuch as this one with pics:
https://www.ford-trucks.com/forums/7...placement.html
Good Luck and we're here if you have a problem.
highboy390fe
15
01-10-2006 05:13 PM
Polkat
11-11-2005 07:30 PM
