disconnect or bypass fuel level sending unit
2005 F350 6.0 superduty lariat
Is there a way to eliminate or bypass, or disable the fuel level sending unit and still operate the truck?
I have a no start that I believe to be caused by a bad fuel level sending unit
Or is the ficm in any way tied to the fuel level sending unit?
Thanks
Thanks
I would be looking at the ficm, batteries or fuel pressure. Too my knowledge the fuel sending unit is strictly a warning device. Someone correct me if wrong. With it being an 05, it could also be a hpop problem such as an stc fitting. You need to do some homework or you'll be throwing a lot of money at it. Checking for codes would be a good place to start.
