Well, it's either the sending unit, the gauge or an electrical problem. How's that for narrowing it down?
I'd start by checking the resistance through the sending unit. If it changes with fuel level the sending unit is probably okay. If not, you'll have to pull the fuel tank and replace it.
You can also check and clean/repair the wire connections at the sending unit and the gauge.
Have you contacted your dealer? I'm sure they can provide specs and better testing procedures.
We have the exact same problem on our 1993 Pace Arrow. Were you ever able to pinpoint the cause? I'd like to fix our fuel gauge, and your experience might help narrow down our search for the cause.
Our fuel gauge has been repaired. The good news is that it turned out to be a cracked fuel sending unit float ball---a ten dollar part. The cracked float ball sank to the bottom of the tank, sending an "empty" signal no matter how much fuel was in the tank. The bad news is that it cost $250 in labor to drop and re-install the fuel tank.
Bluehawk---Yup, the fuel gauge indeed said "empty", but I was there while the mechanic lowered the "empty" tank. It took two large floor jacks and a couple pieces of plywood to drop and raise the tank. Not sure what a gallon of gas weighs, but the tank, when full, holds 75 gallons. In this case I was glad that HE was the mechanic and I was the customer! I was happy to pay the bill---the mechanic truly earned his money on this heavy/messy job!
the easiest way to pinpoint the problem is to remove the wire off of the sending unit and touch it to ground. If the fuel gauge reads full, then that means your wiring and gauge are good and your sending unit is faulty. If the gauge doesn't register then your problem is more likely your wiring or the gauge
