5r110w trans issue
5r110w trans issue
hellp, i have a 2006 6.0 auto
i notices that when i put the truck into reverse is bobbles( almost like a slip but shakes) a little when i touch the gas at first.. also noticed that 4th gear is also acting like it is slipping.
seems almost as if their is not enough pressure in 4th when it tries to shift because i can hardly hit the gas & it still slips a little. & when i go uphill it will slip then bang into gear real hard witch to me says the clutches still have good bite.
i did have a bully dog on the truck but cant see why that would hurt 4th its a high gear that doesn't get a lot of abuse like the lowers.
also is their something that reverse & 4th share as far as shifting because it seems odd that they both are having a issue..
any help would be appreciated.
They both use the direct clutch. If the direct clutch has been damaged, like by running a tuner, it can affect reverse and fourth gears.
When a guy with a cutaway transmission for an avatar answers your thread, you know you have a good answer to your transmission question.
Also 4th gear in these trucks is not used very much at all
For 4th gear to really engage its got to be Way Cold or sometimes when your rolling 40-50 mph and romp on it it may use 4th gear but not often at all
Odds are its 3rd or 5th gear thats jacked up but 4th is NOT used Alot at all
You have the classic symtom of a Bulley Dog Tunner that has TRASHED the transmission
I have a Buddy that had the same thing happen same Tunner same truck same trans same issues
Hows the fluid???????
sharps-Nut
20
11-16-2021 09:13 PM
allimport
02-16-2012 09:14 PM
fletcher969
10-11-2011 06:51 AM
77300i6
10-05-2007 07:34 AM
CruelJohn
04-04-2000 08:05 AM
