In Tank Mods....
In Tank Mods....
Lately I have been experiencing the fuel pickup sucking up air before the tank is actually empty, between 1/4 and empty. I performed the intank mods this weekend as well as installing a b&w hitch. When i took the fuel assembly out of the tank the lower portion of the pickup was broken into many pieces. The screen, foot, check valve, and several other plastic pieces were all in the bottom of the tank. While doing the mod, I did not have anything to measure to for the depth since it was broken. I took the mixing chamber off, put the extension on and check the depth with a stick and making a mark to get depth of tank and comparing against the assembly. The bottom of the pickup tube is about a half inch above the bottom of the tank. I took the return line and clamped a hose and directed it away from the pickup. This is essentially the gist of this mod, correct?
There were still several small pieces of plastic still left in bottom of tank that i could not get out as the pieces i was able to pick up crumbled in my hand while removing. Do I need to replace the foot and screen? Is there an advantage to replacing it or should i just leave it alone? Or should i just put an inline filter before the pump and call it good? It is back together and i have put over a hundred miles on it as is, but the tank is full so its not close to sucking air yet. Where to pick up a foot and screen? Do they come separate or is it all an as one assembly? See pics below.
As removed from tank
With extension
Whats wrong with this picture?
Broke off several T50 torx bits getting the bed bolts out and had to cut one with a torch. Wheres a good place to pick up some replacement bolts?
With extension
Nice ingenuity on the bed. That's the gist of the mod, I think you could get a foot and bolts at the dealer, but I also think you will be fine, as long as no large objects get sucked onto the tube. With the foot, you have a larger surface area in the event something gets stuck to the screen it will suck around it.
Yes. There are lil tabs molded into the side of the cap. I used a brass punch and hammer to knock it loose until i could turn it by hand. I dont know about the others, but i had a lil trouble getting the threads started when going back together, it kept wanting to cross thread. But it finally got going and used the same brass punch and hammer to tighten it back up. Use some sort of punch or block of wood or something to knock it loose. Dont hit it direct with hammer or im sure you will break the cap.
on
I dont know about the others, but i had a lil trouble getting the threads started when going back together, it kept wanting to cross thread. .... Use some sort of punch or block of wood or something to knock it loose. Dont hit it direct with hammer or im sure you will break the cap.
As for not having a pickup foot on there...you should be fine as long as you got the extension really close to the bottom of the tank. That's exactly what happened in "HERS," so I just have the tube as close to the bottom without touching as I could. It's been that way for more than one year, and still works fine.
I need to do this to "HIS," because the foot's broken in that one too. But I did buy a replacement in advance.
LittleBlue79
10-27-2017 12:44 PM
z31freakify
11-24-2015 09:17 PM
wildstang
26
09-18-2015 08:31 PM
