2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Where to find power wire for backup camera and monitor ?
Old 01-29-2012, 04:38 AM
René1234's Avatar
René1234
René1234 is offline
Hello Ford Expedition Enthusiasts,
Last month I have installed a backup camera (inside on the liftgate door) and a monitor (left at the drivers dash) in my 2007 FE-EL Eddie Bauer. I used the power wire to the fog back light - the fog back light is mandatory here in the Netherlands, and I had them installed when importing the car from Florida. The power to the fog back lights runs only when first the front fog lights are turned un (the standard light switch pulled out).
I'm not so happy with this, since I now can only view my cam when putting fog front lights on.
Question: Is there a powered wire (always on when driving, e.g. for back lights) where I can tap on the power cable for monitor and camera ? Hopefully located in the left front, down near the pedal moving switch or in the wirng running underneath the step boards ?
Thanks !
Regards from the Netherlands, René.
P.S. If somebody is interested on the wiring and instalation of the camera and monitor, please let me know and I will upload the pictures I have made.
Old 01-29-2012, 05:20 AM
Ironhand03's Avatar
Ironhand03
Ironhand03 is offline
You need to find a 12V power source that is hot only when you need it.
Your best bet would be to try to tie it into the reverse selector somehow. That way it only comes on when the car goes into reverse.
You probably could pull power from the reverse lights since these only come on when in reverse as long as the amperage pulled from the system isnt higher then it can take.
Old 01-29-2012, 05:56 AM
René1234's Avatar
René1234
René1234 is offline
Alternative ?
Hello,
I would prefer to be able to use the cam anytime, e.g. fir monitoring the load during hauling. Is here any wire nearby the lowr left dash area that is hot when driving ? If yes, what color(-s) dies it have ?
Thanks !
René
Old 01-29-2012, 07:01 AM
chuck s's Avatar
chuck s
chuck s is offline
If you have the HD trailer tow package there's the "12v Aux (trailer battery charge)" connection that's hot all the time the ignition is ON.
-- Chuck
Old 01-29-2012, 08:02 AM
René1234's Avatar
René1234
René1234 is offline
Hello Check - do you have a clue about the color code of this wire to identify it ? Is it running along the left side of the car underneath the door step panels ?
Thanks !
Old 01-31-2012, 05:58 AM
chuck s's Avatar
chuck s
chuck s is offline
At the round RV connector (HD Tow) the standard wire color is black. Shows as OG in the diagram below. Pretty sure there's a connector at the back of the truck where the wire may change color as I've been told the "Bargman" RV connector can be added. If a separate harness runs back there there should be a Blue wire in it for the electric brakes. (Click on the little photos to get to the links.)
There's a required relay and fuse in the trailer tow power panel on top of the radiator shroud that has to be installed. Came loose in a bag with new vehicle..
Not sure the wiring is there if you don't have HD tow.
-- Chuck
Old 02-04-2012, 09:47 PM
gpfarrell's Avatar
gpfarrell
gpfarrell is offline
I did installed a back up camera in our '07 Navigator L.
Underneath the passenger's seat you'll find a green wire with a brown stripe. Actually, two of them!
One of them is the lead for the back up lights, and should you decide to use your camera strictly as a back-up cam, that wire is hot once you select reverse.
If you search the subject, or even posts by me, you'll find more details.
Good luck. For your intentions, the trailering harness sounds great.
Old 03-03-2012, 01:54 PM
TCAS007's Avatar
TCAS007
TCAS007 is offline
René,
where did you install the fog lights at the tail?
Are red turn signals allowed in NL? They're not in many EU countries and most convert the backup lights as turn signal
Did you solve the problem? Show us a pic of the back of your Expedition please.
Old 11-22-2012, 01:03 PM
Cris007's Avatar
Cris007
Cris007 is offline
2007 Naviagtor back-up camera power
Hi friends,
Thanks for posting all this info.
I have a 2007 Navigator and was wondering if I'd be able to find power wires for the back-up lights in the lift-gate.
I'm looking to install a wireless back-up camera (above the license plate) and all I would need is the back-up / reverse 12v to power it up when backing-up.
Your help is much appreciated!
Old 11-25-2012, 02:42 PM
outdoorguy's Avatar
outdoorguy
outdoorguy is offline
backup wires in liftgate?
I'm looking too. Just picked up the Magellan gps with backup camera. "Hoping " the back up light wire is already there in standard harness since it is a factory option.
Originally Posted by Cris007
Hi friends,
Old 03-12-2013, 07:36 PM
mwells's Avatar
mwells
mwells is offline
I just completed this identical installation. I had a wiring diagram for the factory bu camera and tried to locate the power supply for that without success.
I ran a separate wire from the backup lamp, neatly along the gasket, and then alongside the flexible boot which goes into the lift gate (attach it with a lightly tightened cable tie. This will get power to the transmitter.
I connected a second ground wire to one of the bolts holding the wiper motor, and routed down into the gate. I secured the transmitter to a brace with 3m double sided mounting tape and a cable tie. Gather all neatly with cable ties and secure them.
I led the camera wire through the license plate light, by removing the assembly from the outside, routing the cable ( leave enough slack for removal ), and reinstalling the assembly.
Test the installation before you button it up. My works great. Hope this helps.
Old 03-20-2021, 06:11 AM
wilkieb13's Avatar
wilkieb13
wilkieb13 is offline
Possibly helped
If you barely pull out the DC plug and you will probably have to run some wires to where your wanting to run it but at least its constant power and accessible spot.
Thanks !
aramirez
01-05-2016 09:48 AM
savage2211
1999 to 2016 Super Duty
05-27-2007 08:38 PM
windyhill
08-15-2005 04:19 PM
Nitramjr
Electrical Systems/Wiring
02-17-2005 12:13 PM
Guido1
11-24-2001 11:59 PM
Quick Reply: Where to find power wire for backup camera and monitor ?
