1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-19-2014, 06:24 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
Print Wikipost
headlights very dim (help)
Old 01-27-2012, 06:51 PM
nevi325's Avatar
nevi325
nevi325 is offline
hello guys,
i replaced my sealed beam headlights with the plastic housing ones because of how dim they were. i installed the new lights and they are still very dim, seems even worse than before,there is little difference between the daytime running lights and the low beams. in order to see anything while driving i must drive with the high beams on, also my high beam light on the dash is lit when the high beams are not on but its very faint. anyone know of common ground problems?
any help is greatly appreciated.
thanks
Old 01-27-2012, 07:08 PM
Hondaonda's Avatar
Hondaonda
Hondaonda is offline
If both ( sealed beam and composite ) are dim check your voltage going to them should be around 12 - 12.5 also there is a wiring harness you can purchase that will run directly from your battery allowing 13-14 volts to the bulbs.
There is a upgraded " plastic " housing for early F-250's that have the Jeweled ( euro ) look to them that is a huge improvement over the defused style that came on the early F-250's 99-2002.
Old 01-27-2012, 07:20 PM
nevi325's Avatar
nevi325
nevi325 is offline
the ones that i purchased are the 04 style, is that the euro ones? i will check the voltage first thing in the morning. where can you purchase the wire harness? would the bad ground be the one off of the headlight connector?
thanks
Old 01-27-2012, 07:40 PM
Blue Jay's Avatar
Blue Jay
Blue Jay is offline
I would also check the grounds for both lights. Sounds like the low beams are seeking ground thru the high beams thus the dash light being on with low beams.
Old 01-27-2012, 07:41 PM
Hondaonda's Avatar
Hondaonda
Yes, the 2004 are better headlights then the early 2000 ones.
Should be a 9007 here is a link for a kit that will work ( never tried one so dont know about the quality )
http://www.puredieselpower.com/catal...ade-p-111.html
Yes a bad ground can and will also cause the problem.
Old 01-27-2012, 08:24 PM
sand_fiend's Avatar
sand_fiend
sand_fiend is offline
I have one light that kept going dim. pulled out the plug and looked at it. the center wire in the plug got pushed back a bit and was not making a good ground. i took a little screw driver and bent the tab a little then pushed it back in.. works great now..
Old 01-27-2012, 11:04 PM
nevi325's Avatar
nevi325
nevi325 is offline
do you mean the ground that is directly off of the light socket?
Old 01-28-2012, 09:29 AM
Blue Jay's Avatar
Blue Jay
Blue Jay is offline
Yes that would be it! Use a voltmeter or test lamp between it and battery neg. terminal.
lrh2phish
2009 - 2014 F150
01-14-2019 01:46 PM
Bulldog187th
07-19-2017 08:10 PM
davidjurss
2004 - 2008 F150
03-30-2013 09:11 AM
Rustymuffler
Electrical Systems/Wiring
01-11-2007 08:49 AM
HUNTER10
25
08-24-2006 11:35 PM
Quick Reply: headlights very dim (help)
