Shackle Help!
01-25-2012, 03:14 PM
on
Shackle Help!
Putting new bushings in the shackles. But the shackle has this weird sleeve that won't allow the bushing to fit in.
Do I force in the bushing or remove this so it fits better?
01-25-2012, 03:43 PM
on
It needs to come out, the sleeve should have rubber around it. that looks like a larger sleeve does your shakle bolt fit snug in that?
01-25-2012, 03:45 PM
on
No, it had rubber in between that and another sleeve then the bolt inside that. I just didn't know if this was part of the shackle of the old bushing.
01-25-2012, 04:01 PM
on
I'm pretty sure it needs to be removed but i would say wait for another opinion. If you are using poly bushings they should slide right in and even get a little grease to keep them moving.
01-25-2012, 04:03 PM
on
K will do, going to school now so won't be back til 9 so should hopefully get enough responses by then. Thank you for your input.
01-25-2012, 04:16 PM
That is the outer sleeve of the bushing. I carefully sawed mine in a couple spots for easier removal. I tried to push mine out with a socket and got the socket stuck. Be careful if you try it that way.
01-25-2012, 04:22 PM
YEP IT IS THE OUTER SLEEVE LIKE WHAT GRINNERGETTER SAID , NEEDS TO COME OUT AND SAWING IT WILL WORK , I HAVE ALWAYS USED A TORCH AND BURNED THEM OUT !
01-25-2012, 06:43 PM
on
Kinda hard to see from this pic
but it has a heavy duty panel/muffler cutter on the top while the bottom is rounded
I have one of these from snap-on
they list it as a control arm bushing cutter
works great on all sorts of things
Reason: add pic
01-25-2012, 10:28 PM
on
Thanks everyone, I will get it done tomorrow.
Jarkill
22
08-07-2016 03:06 PM
jimcar-9
03-14-2014 01:42 PM
cadunkle
11-16-2010 08:35 PM
needhelp49
06-06-2008 08:06 PM
vegas
20
03-18-2005 11:00 AM
