429 emissions system
I have a 1989 F-700 Dump that has the 429 in it. It currently doesn't run due to an electrical issue, but that isn't the main point. Is there a way to just rip off all the useless hoses and emission systems off of the engine. It would make it so much easier to work on and I figure just having a pure engine would run better (when it is running again). I don't care about emissions, fuel economy either, or the damage to the environment. It is a farm truck.
PCV: Needed, unless you like an oil mist outside and sludge inside.
EVAP system: You can vent to the air if you like, make sure the vent is well back and not just a cut hose in the engine compartment.
EGR if equipped: You may have to do some timing or jetting, or maybe nothing.
AIR injection: Some plugs, probably no effect.
This a carb'd motor?
Might run the same, might run worse, you'll have to see.
If you have cut hoses hanging there, you should run them down to either reconnect them if they are important, like the evap system and pcv, or make sure they are not a vacuum leak or an pathway for contamination to get into your engine or carb.
Does this thing have a cat?
Pulling an air pump and the plumbing usually does nothing as long as the injection ports are plugged so you don't have an exhaust leak. The only issue is to find a belt that will work without the pump pulley to wrap around, if that's even an issue.
jw miller
26
08-11-2007 01:18 PM
