just found new possible quirk. Not sure. but my transmission seems to shift extremely hard when i shift into the passing gear. is this normal? almost sounds like i hear the rear end or slack in the driveshaft. only in the passing gear though. any thoughts?
I have an 04 that I bought used with about 120k on the engine. I was getting a rough shift when it tried to downshift from OD. It would jump and surge and figured it was a tranny problem. Took it to dealer and turned out to be two bad ignition coils. They replaced coils and plugs on those cylinders and it solved the problem.
