6.2L V8 Discuss the 6.2L V8
Which Engine Oil and Filter do you use?
Old 01-25-2012, 12:01 PM
RAPR's Avatar
RAPR
RAPR is offline
Which oil brand/type and oil filter do you use to prevent engine wear to keep your truck running as long as possible?
My first oil change I went with Royal Purple 5W-20 at 3500miles. Now I'm at 7400miles (oil life gauge says 64%) and about to perform my second oil change. Not sure if there is a better oil out there that will make my truck last forever. I'm bouncing between sticking with RP or switching to Mobil 1...all while using the Mobil 1 oil filter.
PS- the company I work for pays for my maintenance, so I don't mind changing the oil a little more often than necessary and can purchase a little pricier oil...as long as its not at the price point of Amsoil RD20.
Old 01-25-2012, 01:36 PM
fz1dave's Avatar
fz1dave
fz1dave is offline
Super Duty
Motorcraft 5w20 oil and Motorcraft filter.
Old 01-25-2012, 01:55 PM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
Same as Dave, Motorcraft stuff...
Old 01-25-2012, 03:14 PM
real_texan's Avatar
real_texan
real_texan is offline
whatever the dealer uses
Old 01-25-2012, 08:11 PM
RZAR's Avatar
RZAR
RZAR is offline
Motorcraft here also. I get the filter and oil from walmart for cheap.
Old 01-25-2012, 08:28 PM
kmonty2's Avatar
kmonty2
kmonty2 is offline
I buy Mobil 1 when it is on sale at Auto Zone, $30 for 5 quarts and filter. So I buy 2 the first time since it takes 7 quarts, and now I only buy 1 special each oil change.
Old 01-25-2012, 11:05 PM
rkmfordman's Avatar
rkmfordman
rkmfordman is offline
Motorcraft all around.Did you notice any gain in mpgs when you switched to royal purple rapr?
Old 01-26-2012, 07:17 AM
RAPR's Avatar
RAPR
RAPR is offline
I change to RP at the same time I did the lift and bigger tires. If there was any increase in mpg, which I doubt, it was unnoticed due to the drop in MPG due to the speedo being off. I bought an Ultra-Gauge to obtain correct speed and mileage readings so can start getting correct mpg measurements again.
Old 01-27-2012, 09:48 PM
Fawcett's Avatar
Fawcett
Fawcett is offline
5w20 Motorcraft w/ Motorcraft Filter $32 @ Walmart!
Old 01-28-2012, 12:16 AM
stutzismydog's Avatar
stutzismydog
stutzismydog is offline
Mobile One and a Wix oil filter, it doesn’t get any better than this.
Old 01-30-2012, 10:54 AM
devongarver's Avatar
devongarver
devongarver is offline
I used the Motorcraft 5W-20 oil and Motorcraft filters on my truck(6.2) and my wife's truck(5.0 F150) for the first few changes, but have since been experimenting with the Fram XG filters which are their best filters Fram makes. I have used these filters on all of my other vehicles with positive results, using Mobil 1 Full synthetic. I am considering trying another filter next change as I have noticed the oil pressure has increased a fair amount in both trucks while using Fram filters. This makes me wonder if it is restricting the flow more than the motorcraft, but at the same time, makes me wonder if it filters better than the motorcraft, which wouldn't surprise me. Either way, I think I am going to try a quality NAPA filter next. Either way, for now I am still using Motorcraft oil because of the price point and availability.
Old 01-30-2012, 11:25 AM
stutzismydog
Napa Gold and Wix are the both made by the same company,....WIX. I am shure that Motercraft oil and filters are not made by Ford and I would like to ask if any body knows who makes their products for them.
etown
2004 - 2008 F150
10-24-2011 10:42 PM
93nighthawk
Aerostar
18
09-09-2009 12:16 AM
diesel_hillbilly
06-26-2009 09:46 PM
Milwaukee1979F150
21
04-17-2008 10:28 AM
Fordafied
1999 to 2016 Super Duty
08-02-2004 06:55 PM
Quick Reply: Which Engine Oil and Filter do you use?
